Author Topic: Monitor blues  (Read 2225 times)
zmo
  • Last login:May 16, 2003, 06:06:49 pm
Monitor blues
« on: July 07, 2003, 12:56:43 pm »
I have a arcade monitor hooked up to a computer running with a ms-dos operaing system...ecept all I get it a blue screen and some lines.
Ms dos is conigured to run on a vga setting if you need to know.
the monitor cable has 5 wires and the monitor has six(might be the problem
BobA
  • What Me Worry?
Re:Monitor blues
« Reply #1 on: July 11, 2003, 12:43:57 am »
Tell us what your connected from your PC card to which monitor inputs and perhaps someone can make a guess at what might be wrong.  Did you do the standard VGA cable hack from the PC to Jamma Site and what video card are you using with which programs loaded to give you arcade output.  What exactly do you mean by a vga setting?  What res and what freq are you sending to the arcade monitor?
BobA
