Author Topic: How to connect Internet to TV?  (Read 2245 times)
BobbyG66
  • Last login:November 13, 2016, 11:52:09 am
  • Current project: Dodgeball
« on: June 11, 2009, 08:23:59 am »
I am looking to get internet access on my TV.
Primarilly for streaming TV shows and movies.
What are some of the best ways to go?
XBOX with XBMC or a PC? What else is there?
BG66
Half of the people you meet are below average.
  • Last login:January 30, 2026, 04:39:53 pm
Re: How to connect Internet to TV?
« Reply #1 on: June 11, 2009, 11:30:00 am »
Depending on what you want to do...
Xbox 360 will allow you to stream select Netflix titles.
Using Tversity, you can stream content from your computer to either an Xbox 360 or PS3.  Tversity also allows you to stream some internet feeds to exither the Xbox 360 or PS3.
CCM
« Reply #2 on: June 11, 2009, 01:19:41 pm »
I use my PS3 and PlayOn  (installed on my PC) to stream HULU, Netflix, and Amazon on-demand movies.
I use Twonky media server to stream my movies to the PS3.
« Reply #3 on: June 11, 2009, 01:45:47 pm »
PlayOn?  I'll have to look into that.  I've been wanting to get Netflix on my PS3...  hmm.
CCM
« Reply #4 on: June 11, 2009, 02:26:15 pm »
www.themediamall.com
PlayOn kicks ass...
PlayOn lets you watch Netflix, Hulu, CBS, YouTube, CNN, ESPN and more on your TV
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #5 on: June 11, 2009, 03:07:53 pm »
If you go the PC route, Hulu recently released an application called Hulu Desktop that is superb.
Best Kid iPad Apps
protokatie
« Reply #6 on: June 14, 2009, 02:36:34 am »
I'm going the PC route myself, but for some reasons that might be different than what others would do it for.
Basically, I have 2 PCs hidden in the livingroom (the one under the corner table is the file server with 2TB of HD space, and the one hidden behind the couch is called "livingroom" on the home network and is essentially the entertainment center). I use this route basically because I don't watch actual TV (no cable/sat tv hookup) so I am content with just internet content and the stuff on my fileserver (almost full BTW).
The livingroom PC I have isnt hooked to a TV, but a decent sized monitor. I got a remote for it tho, which works excellent for controlling BSplayer (BSplayer has the best configuration for remote controlling I have ever seen, including using something like oh say... a minipac or keywiz to control every aspect of it (including what key opens the "about" window for the program))
If I ever do get a TV hookup, I will just get a capture card for the livingroom PC and use either a computer monitor or a TV out card for the display.
As per you, I would recommend using a PC for a few simple reasons (that are different for me going to that option):
1. Pc's can be configured and parts can be harvested/exchanged over decades (less chance of obsolesence)
2. Pc software for handling DVR/internet/etc tends to be better and may "last longer" (see #1)
3. Pc's are cheap (or free in many of my cases [NO! I didn't lift them! They were given to me!]) and wont tie up your game console for that use (In case you want to use both services (internet TV and gaming) at the same time, with a PC setup, you can move the console to another screen/room without disrupting the system you have setup for TV)
Anyways, just my ramblings, take what you can from them.
ps. The cost of my entire fileserver and livingroom entertainment center systems was $ 310  (120x2=240 for 2 1TB external drives + 45 for a computer remote + 20 for ethernet cable + 5 for a CR2032 bios battery) Everything else was either given or harvested from older stuff I had.
gonzo90017
« Reply #7 on: June 26, 2009, 12:52:34 am »
If you decide to go with a pc you should  try out Zinc. It let's you acess a lot of online video from most of the major networks and online networks like Revision3.
BobbyG66
« Reply #8 on: July 02, 2009, 12:23:44 pm »
Thanks for all the help and ideas.
My boys just bought an Xbox 360. So I working on setting that up know.
We signed up for Netflix, but the quality is really bad.
I am seting up Tversity and Orb.
Looking to get some internet access now.
Looking for sites that I can watch different series and such.
BG66
CCM
« Reply #9 on: July 02, 2009, 12:33:22 pm »
BG66
HULU!
