Author Topic: Best Resolution for SF 2?  (Read 1910 times)
savj14
  • Last login:April 06, 2020, 07:52:46 pm
« on: June 08, 2009, 03:55:16 pm »
I have a WG D9200 and an ArcadeVGA and have been using 392 x 240. It looks pretty good and was just wondering if this is the best resolution to use.
Is there a better built-in resolution for the ArcadeVGA? Or can I use Powestrip to add an even close/better resolution? Just wanted to make sure.
massive88
Re: Best Resolution for SF 2?
« Reply #1 on: June 08, 2009, 06:05:49 pm »
Im not an expert at using the ArcadeVGA and Arcade monitors, but I was under the impression that the idea was to be able to run the games at their native resolution.
You can find a games native resolution from MAWS (I think Mame will know it too)
http://maws.mameworld.info/maws/romset/sf2
Street Fighter 2 appears to be 384x224, which, again Im assuming, would make it the optimal resolution for you to run it at if you are able.
savj14
« Reply #2 on: June 08, 2009, 09:55:36 pm »
388x244 is the closest ArcadeVGA resolution, but there are significant top/bottom borders. Going with 392x240 actually looks better.
Is 384x224 obtainable via PowerStrip custom resolutions or any other method?
« Reply #3 on: June 10, 2009, 08:06:26 am »
Really?? I don't recall that mode?
I think that is the best mode.
savj14
« Reply #4 on: June 10, 2009, 04:28:10 pm »
Oops I meant 384x288......but 392x240 is still better
« Reply #5 on: June 11, 2009, 08:50:08 am »
Also note that 384x288 is no good as the refresh rate is too low (~51Hz IIRC). This will mean skipped frames...
Stick with 392x240 :)
savj14
« Reply #6 on: June 11, 2009, 11:13:37 am »
Very good. Thanks for the help =)
