Author Topic: How do you mount your glass or plexi screen guard?  (Read 1806 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: June 08, 2009, 03:07:44 pm »
My cab is almost done. I'm going to mount the plexiglass soon. Does anyone have advice on how to do it?
Ginsu Victim
  • Comanche, OK -- USA
Re: How do you mount your glass or plexi screen guard?
« Reply #1 on: June 08, 2009, 03:11:58 pm »
Use the buttons to hold it. You typically won't need anything more than that.
I iz dum.
« Last Edit: June 08, 2009, 04:00:04 pm by Ginsu Victim »
  • Last login:Yesterday at 01:37:16 pm
« Reply #2 on: June 08, 2009, 03:28:04 pm »
I think he's talking about the glass over the monitor.  I'd use a slot cutter to route a groove for the glass to sit in at the bottom.  I'd use small cleats to support it on the sides and I'd make the glass a little long on top and tuck it behind the panel that is underneath the marquee (typically the speaker panel).   :cheers:
Ginsu Victim
« Reply #3 on: June 08, 2009, 03:59:12 pm »
Yeah, looks like I read that wrong.
severdhed
  • RIP Dinosaur Hippo
« Reply #4 on: June 08, 2009, 11:52:04 pm »
i used four metal corner braces that i picked up at a hardware store.  mounted them on the sides of the cabinet, and the plexi just rests on them.  there is a small strip of wood at the bottom for it to sit on. i cut the plexi so that it just fits snug between the sides of the cabinet, friction holds it in place.
