Author Topic: How do you make a detachable control panel?  (Read 3862 times)
Aabra
  • Last login:September 11, 2012, 01:12:46 pm
« on: June 08, 2009, 12:24:09 pm »
I'm in the process of designing a cabinet.  It will be a 4 player cabinet so in order for me to get it through the doors in my house I need to be able to detach the control panel easily.  All of the designs and pictures that I've seen never seem to explain this process in detail.
I've seen a control panel clamp set here:  http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=70&products_id=204
How do these work exactly and are they even what I should be using?  If somebody could explain the process and take a picture or two of how their own detachable control panel is attached to the main cabinet I would greatly appreciate it.
  • Last login:Yesterday at 04:07:25 pm
Re: How do you make a detachable control panel?
« Reply #1 on: June 09, 2009, 04:42:57 pm »
Use some LATCHES.
Aabra
« Reply #2 on: June 12, 2009, 02:36:17 pm »
Thanks.  So I was looking at the right thing then.  :)  I guess the bottom of the CP needs to be hollow then for this to work.  I'll have to figure out a good place to put the control interface.
Hitek
  • Last login:September 29, 2013, 07:20:25 pm
« Reply #3 on: June 14, 2009, 09:00:04 pm »
It doesn't necessarily need to be hollow, it just depends on how you want to mount it. My CP has a locked hinged bottom and I use the clamps.
Aabra
« Reply #4 on: June 15, 2009, 05:34:25 am »
Ahh, that's much clearer.  A picture says a thousand words.  Thanks a lot.  :)  Is it secure though with only the 2 latches holding it on there?  (1 on either side)  Would it be better to go with 4 or is 2 enough?
« Reply #5 on: June 15, 2009, 10:05:55 am »
2 is probably enough but I'd go with 4 - put 2 on the bottom so it won't pull up and then 2 in the back so it won't pull forward.
Hitek
« Reply #6 on: June 15, 2009, 10:44:34 am »
2 is plenty. My CP is 49" wide and they hold it down just fine, even with 4 adults playing. You could use 4 if you wanted, but I don't think it's necessary at all.
Aabra
« Reply #7 on: June 15, 2009, 02:09:31 pm »
Thanks a lot guys.  I really appreciate all the information and have a very clear idea of what I'm going to do now.  :)
