Author Topic: Apply U360 map to other emulators?  (Read 1312 times)
Kayden
  • Last login:February 17, 2023, 07:20:44 pm
  • Oh crap! Is it suppose to spark like that?
« on: June 04, 2009, 11:32:47 pm »
My Mala is set up to have P1 4 way and P2 mouse while in Mala.  When I load mame games, it applies the proper map for the game.  However, when I run zsnes through Mala, the map stays the same, so I have a 4 way and a mouse instead of two 8 ways.  How do I set everything up so other emulators load double 8 ways on game launch and revert to 4way+mouse when returning to Mala?
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: Apply U360 map to other emulators?
« Reply #1 on: June 05, 2009, 09:00:23 am »
Which u360 plugin are you using?
Robots will kill you.
Arcade Addiction
Kayden
« Reply #2 on: June 05, 2009, 09:25:09 am »
I'm using fatfingers' plug in.
I read somewhere that you can make a batch file to do it, so I tried that, but it was really flakey.  Sometimes it wouldn't apply and sometimes it would apply after a while and other times running the batch file would make the screensaver mode turn on and when I quit the game, the only way I could get back into Mala was to hit the keyboard (sticks and mouse didn't work.)
Then I remembered the "default" map and modified that to be double 8s.  Then everything started working. :shrug:
Kayden
« Reply #3 on: June 05, 2009, 03:07:59 pm »
Ok... it's apparently not working.   :-\
Since I changed the default profile from mouse to 8 way, my second joystick stopped being a mouse in Mala.
In windows I had P2 a mouse.  Then I started Mala and the mouse stopped working.  I know it applies a mala map when mala starts, but that's set up to use a mouse...  I wonder if it's applying the mala map and then the default map...
Kayden
« Reply #4 on: June 05, 2009, 04:33:48 pm »
I really wish I could find my solutions before I ask stupid questions.
I think I had both LED Blinky and FatFingers' trying to map the sticks.  :(
I didn't know that's what "Joystick Digital Restriction" meant.  Perhaps in a future version you could rename that to something like "Change U360 Map automatically" for other stupid people like me out there?
arzoo
    • LEDBlinky
« Reply #5 on: June 05, 2009, 08:46:22 pm »
No worries. Glad you got it solved.
Arcade Addiction
