Author Topic: Must have mame to run pc games in mala?  (Read 2495 times)
Hazzard
  • Last login:July 24, 2009, 10:00:48 am
« on: May 31, 2009, 08:02:27 am »
Hey!
I cant seem to configure mala for my precious pro-pinball games.. Do I HAVE TO use some mame games/emulators make this work?  :-\
I allways get an error about mame exacutable not found/set...
Colud anyone push me in the right direction here?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Must have mame to run pc games in mala?
« Reply #1 on: May 31, 2009, 10:04:13 am »
You can create a dummy file such as mame.cmd with notepad and point the executable path to that.  Doesn't really matter since you won't be using mame, and it will get rid of that error.  I'm not sure what other errors you'll get after that when Mala tries to generate a Mame main game list.
You may need to get a mame.xml file so Mala can initially generate a game list.  You could always download Mame just long enough to set up Mala initially.  Its not like you would have to download roms or setup and configure Mame.  I don't see the fact that you won't be using Mame as a big deal.  Just a couple of errors to get through.
Hazzard
« Reply #2 on: May 31, 2009, 10:56:46 am »
Thank you very much for your reply!  :applaud:
I will try your remedy`s and get back to you if anything else seems hopeless.. :dunno
Henning
