Author Topic: Swapping HAPP buttons for Sanwa Buttons  (Read 12336 times)
langdonx
  • Last login:August 18, 2009, 01:38:11 pm
« on: May 28, 2009, 02:51:59 pm »
I bought a SlikStik Classic Controller last year (which are now sold as North Coast Custom Arcade's Classic Controller).  It's a great control deck, but after playing on a MadCatz SFIV TE FightStick, I really think I prefer Sanwa buttons over Happ buttons.
My question is, if I want to swap out a few of the Happ buttons on my SlikStik deck with Sanwa buttons (from lizardlick), will I run into much trouble?  Is the wiring much different?  I'm generally a novice when it comes to tinkering, but as long as I don't have to solder very fine points, I should be able to handle it.
Another thing I'm worried about is the size of the drilled holes... will the pre-existing holes need to be cut larger?  Do I need a drill press to do this, or a hand held drill cut it?
TIA!
Franco B
Re: Swapping HAPP buttons for Sanwa Buttons
« Reply #1 on: May 28, 2009, 03:06:12 pm »
The wiring will be exactly the same.
As for hole sizes, your current holes will be 1 1/8" (28.65mm) whereas most Japanese buttons require a hole of 30mm so you will need to open out your existing holes. I wouldn't recommend using a hand drill for this.The best thing to do would be to use a drill press as you suggested.
Line up your hole using a 1 1/8" bit (any type bit will do) and insert it into the hole to find the center. Clamp the workpiece and then use a 30mm Forstner bit to open the hole out. Make sure you have a scrap piece of wood below your CP to avoid blow out.
You could drill a 30mm hole in a piece of material and then use that to template route the holes bigger but I think the drill press would be the easiest solution.
langdonx
« Reply #2 on: May 28, 2009, 03:23:28 pm »
Thanks for the quick reply!
I'm guessing Home Depot/Lowe's probably doesn't rent drill presses... will have to figure something out if I want to move forward... I could try the hand-held and just glue them back in if I mess up, hehe. ;)
ETA:  Maybe I'll just buy 6 Happ competition push buttons to see how similar they are to the OBSF 30's.
« Last Edit: May 29, 2009, 02:27:01 pm by langdonx »
Jack Burton
« Reply #3 on: May 28, 2009, 04:29:56 pm »
Don't bother with a drillpress for a job so small.   Best tool is this:
Any kind of round wood file will probably do.  Make sure it is a fine toothed one.  It shouldn't take more than an hour or two to round out your holes a little bit.
HAPP competitions are very different from Sanwa.  They feel almost identical to standard pushbuttons.
Sanwa's are very soft and have a very short engage distance.
It won't hurt your stick to file the holes out to 30mm.  The old buttons will still fit in just fine if you make sure you screw the nut on tight.
« Last Edit: May 28, 2009, 04:31:51 pm by Jack Burton »
Chris
    • Chris's MAME Cabinet
« Reply #4 on: May 28, 2009, 04:38:41 pm »
Step bit, perhaps?
--Chris
Jack Burton
« Reply #5 on: May 28, 2009, 04:45:22 pm »
I'm not sure that would work on 3/4" mdf
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #6 on: May 29, 2009, 09:33:23 am »
it is for metal only, but  you can taste. buy ver. which has 2 cutting edges
maybe they are from three, do not buy from one cutting edges.
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #7 on: May 29, 2009, 10:08:34 am »
ETA:  Maybe I'll just buy 6 Happ competition push buttons to see how similar they are to the OSBF 30's.
They feel nothing alike.
langdonx
« Reply #8 on: May 29, 2009, 10:59:15 am »
Nice... thanks for all the input.
A fine-toothed round wood file sounds like my best bet.  I think I'll try it on Player 2 side and see how it goes.
Is there a better place to order Sanwa OBSF30 buttons from?  LizardLick is only processing May 11th orders right now, so I'd probably have to wait 3-4 weeks if I did order them Monday.
« Last Edit: May 29, 2009, 02:26:09 pm by langdonx »
jasonbar
  • Last login:December 14, 2025, 11:29:57 pm
  • Dr. Inferno
    • The Infernolab
« Reply #9 on: May 29, 2009, 01:46:24 pm »
Or maybe use a half-round file, if you find one of a good size/curvature.  Might make your work go faster, but it might also over-file if you're not careful... :dunno
http://www.mcmaster.com/catalog/115/gfx/large/4218a16p1l.gif
-Jason
1UP
  • Token Junkie
    • 1UPArcade
« Reply #10 on: May 29, 2009, 03:18:05 pm »
I wouldn't solder the buttons in at all.  Use quick disconnects, they are less fuss, and if you decide you like different buttons later, you don't have to desolder or cut wires again.
My other job...
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #11 on: May 29, 2009, 04:10:27 pm »
+1 for not soldering your control panel.
Here's a thread on quick disconnects: http://forum.arcadecontrols.com/index.php?topic=90837.0
-Jason
langdonx
« Reply #12 on: June 26, 2009, 08:35:16 am »
My buttons arrived from LizardLick earlier in the week and I finally had a chance to swap them out last night.
I bought this filing set from Lowes, which did the trick.  Thankfully, most of the holes required very little filing.
So I went from this:
To this:
And on the top side:
Since that task really was sooo simple, I want to try doing more now.  In addition to replacing other buttons on the control deck,  I was thinking of going with a square gate on the joysticks.  I ultimately decided that a square isn't going to make playing non-fighting games very much fun.
So I was looking into replacing the bat tops with ball tops, but it doesn't look like the joysticks I have (Happ Competition) can be replaced.  I say this because LizardLick nor HappControls seem to carry ball top replacements for Happ joysticks.  Can someone confirm this assumption?
Thanks again for all the advice!
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #13 on: June 26, 2009, 09:11:32 am »
See this recent product announcement .
stainless.
discontinued?
JMB
  • Last login:July 20, 2023, 07:29:22 pm
« Reply #14 on: June 26, 2009, 10:38:07 am »
Here is another option for ball tops for your comps.
http://www.tornadoterrys.com/surplus.htm
You can't go wrong with either vendor.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #15 on: June 26, 2009, 11:10:35 am »
I was going to suggest Terry's, but I don't see his balltop shafts listed anymore. (I see the complete setups, just not stick only)
