Author Topic: PS2 Hacking: What's safe to cut away?  (Read 1000 times)
king88mob
  • Last login:November 10, 2003, 10:14:10 am
« on: July 05, 2003, 12:04:03 pm »
I bought a MadCatz dual-shock controller to hack around with, and as promised, this was a very easy controller to solder to.
I have a little problem though: it has 2 motors for vibration, and of course the two analog sticks.
What do people usually do with these? It would seem logical that the two motors can simply be disconnected (i've had pads whose vibration systems have failed, and they still work fine) I"m not so sure about the analog sticks. With them attached, i can't easily fit my gamecontroller into the project box i was hoping to put it in, but that's a fairly minor issue.
Any Advice?
reighty
  • Last login:January 21, 2004, 09:11:16 pm
Re:PS2 Hacking: What's safe to cut away?
« Reply #1 on: July 05, 2003, 04:10:16 pm »
I know that the motors for force feedback can come off, however for the analog I have heard stories from others (when using different pads than yours) that taking off the analog sticks off can cause weird affects such as the controller permentily reads the stick all the way in on direction, which makes sense do to how pots work.
I say just leave the analog controller alone.
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #2 on: July 05, 2003, 06:04:51 pm »
Some analog sticks I've seen you can just unscrew from the controller if you twist 'em the right way.  worth a try, maybe.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
