Author Topic: LED-Wiz power question  (Read 1423 times)
masterosok
  • Last login:September 12, 2009, 09:51:18 pm
« on: May 28, 2009, 02:58:31 am »
I am using the LED-Wiz with the RGB led modules and I was curious if it is OK to run power from more than one LED to the same terminal on my terminal block.
I have power coming from my psu wired to my 8 terminal, terminal block and daisy chained to all of the terminals on the right side. I was just wondering if I could run the power wire from 2 different leds to the same terminal without any issue?
« Last Edit: June 01, 2009, 07:15:17 pm by masterosok »
mahuti
Re: LED-Wiz power question
« Reply #1 on: June 15, 2009, 10:50:27 pm »
I've done that. Shouldn't be a problem. Multiple lights on the same numbered terminal should be just fine.
