Author Topic: Solved - Can Advmenu command Windows to shutdown on exit?  (Read 1461 times)
Ummon
  • Trade Count: (+13)
« on: May 21, 2009, 09:40:02 pm »
Looking at the docs, I'm guessing yes, but I'm not sure what I'd put in there. ?
« Last Edit: May 23, 2009, 04:23:00 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
Ummon
Re: Solved - Can Advmenu command Windows to shutdown on exit?
« Reply #1 on: May 23, 2009, 04:26:09 pm »
I asked somewheres else, and come to find out it's the 'misc_exit' feature. Default is 'normal' (quit). Change to 'shutdown' - ctrl_esc key is the key. Wonder if that's changeable?
Yo. Chocolate.
Stephen Hawking
tikbalang
  • Last login:May 07, 2013, 05:04:54 pm
    • MAME BootCD's for DOS
« Reply #2 on: June 08, 2009, 06:29:53 am »
if you're using the latest version (v2.5.0):
---- 5.7.3 idle_screensaver_preview ----
Selects the preview type to use in the screensaver. Like
the preview option.
idle_screensaver_preview none | exit | shutdown | play
| snap | flyers | cabinets | titles
Options:
    none - Shutdown the monitor using the VESA/PM services
        if available. Otherwise use a black image.
    EXIT - Exit from the application.
    SHUTDOWN - Shutdown the machine.
    snap, flyers, cabinets, titles - Start a mute slide show
        of the specified image type (default snap).
    play - Start a snap slide show using the animated
        snapshots and the game sounds. The static
        snapshots are ignored.
this version can exit/shutdown when idle.
Ummon
« Reply #3 on: June 08, 2009, 06:22:38 pm »
Helpful for some, I suppose. Not something I'd likely ever need.
By the way, yes of course the key assigned is configurable. Sheesh. I need to look more diligently in the rc file. I did look through the docs, though, and found nothing.
Yo. Chocolate.
Stephen Hawking
