Author Topic: Should a J-Pac work with a Supergun?  (Read 1046 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: May 19, 2009, 03:35:32 pm »
Because mine doesn't give me anything via mine! I have an Arcade@Home Supergun and plugging in my J-Pac with console adaptors lights all the test LEDs up (so it should work) but no picture is produced on my TV screen... suggestions and feedback please!
Jack Burton
Re: Should a J-Pac work with a Supergun?
« Reply #1 on: May 19, 2009, 03:59:30 pm »
hmmm.  A J-pac on it's own does not create 15khz signals right?  I'm guessing that your supergun is expecting one and you are feeding it at least 31khz.
« Last Edit: May 20, 2009, 06:44:19 am by Jack Burton »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: May 19, 2009, 04:30:20 pm »
hmmm.  A J-pac on it's own doesn't not create 15khz signals right?  I'm guessing that your supergun is expecting one and you are feeding it at least 31khz.
+1 for initial suspicion
More details about your setup please.
Working: Not Enough
Projects: Too Many
Progress: None
slapaham
« Reply #3 on: May 20, 2009, 03:47:46 am »
Let me know what you need to know and I'll let you know! ;D
I was on the assumption that with the console to J-Pac video leads from Ultimarc would convert the signal to 15Khz...? I understand a J-Pac with a PC alone wouldn't do this and the extra requirement of an ArcadeVGA or Soft15Khz would be needed... I did once get signs of life from the J-Pac by splitting the signal with a PC setup through my old Supergun set up (a Vogatek MKII)...
