Author Topic: Happ 27" bezel doesn't fit D9800  (Read 4976 times)
BlazzingFlippers
  • Last login:November 26, 2015, 04:34:09 pm
« on: May 18, 2009, 06:05:15 pm »
I'm pretty frustrated.  :banghead:  Ordered the 27" bezel from Happcontrols.com for my D9800 and it doesn't fit.  Not only is the entire thing about 1 1/2 inches too narrow, but the screen cutout inside is too narrow as well to go over the screen.
Any ideas?  Does anyone know of a bezel that actually fits a D9800 and fills the gaps?
The one I ordered has the following dimensions:
25.65" w  x 23.87" h  Outside21.19" w  x 16.13" h  Inside
The opening between the 2 sides of my cabinet being is 27", so I'm almost 1 1/2 inches short.   Did I order the wrong bezel?  I ordered it from this page:  http://www.happcontrols.com/monitors/49010500.htm
I just noticed that the bezel for the curved 27" is
29.5" w x 29.25 h"  Outside     21" wx 15.575 h" Inside
Should I have ordered this one instead?  Do you think this one, although it says for a curved CRT, would work?  Why would they make the flat sreen bezel that much shorter on the sides??
I've added some pics so you can see this gap I'm dealing with:
http://i43.tinypic.com/vorhpc.jpg
http://i39.tinypic.com/qybqcx.jpg
« Last Edit: May 18, 2009, 09:23:09 pm by BlazzingFlippers »
YoGaBaR
  • Yeah im in the club
Re: Happ 27" bezel doesn't fit D9800
« Reply #1 on: May 18, 2009, 11:18:12 pm »
so you have a flat screen or a curved screen.
Is the bezel for a curved or flat screen
« Last Edit: May 18, 2009, 11:20:27 pm by YoGaBaR »
jscott3093
  • Last login:September 22, 2009, 01:35:10 pm
« Reply #2 on: May 19, 2009, 10:56:00 am »
The WG d9800 is a flat screen monitor and there is a different bezel for that. I think you probably ordered the normal rounded monitor bezel.
whammoed
  • Last login:Today at 12:48:37 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #3 on: May 19, 2009, 10:59:31 am »
Since the screen is flat it is very easy to make your own.  Go to an art supply store for some thick black cardboard and cut it to size inside and out.
BlazzingFlippers
« Reply #4 on: May 19, 2009, 01:40:23 pm »
Hey all I have the D9800 which is a flat screen CRT.  I ordered the bezel for flat 27" CRT from right here:
49-1857-00
 27" Flat CRT Monitor Bezel
So I know I ordered the correct bezel.  Its just too narrow.
BlazzingFlippers
« Reply #5 on: May 19, 2009, 06:29:32 pm »
Just for the record for anyone else out there, Xarcade contacted me and said their bezel is custom because the Happ one is too small so if you do order the D9800 from Xarcade, make sure you add the bezel option.  I totally regret not getting it.  The Happ bezel was cheaper so that is why I ordered from them instead.  Live and learn...
BTW this now means I have this bezel I can't use.  If anyone wants to buy it off me for cheap let me know.  The dimensions are listed above.
« Last Edit: May 19, 2009, 06:33:47 pm by BlazzingFlippers »
bungy
  • Last login:February 06, 2020, 09:33:40 am
« Reply #6 on: August 14, 2009, 04:49:38 pm »
I have the exact same problem.  The Happ bezel doesn't quite fit as my inner cabinet width is 27.5". Did you end up getting the bezel from Xarcade?  I couldn't find the dimensions on their website so I'm not sure it would work for me.
sean-o-mac
  • Last login:December 12, 2010, 06:00:10 pm
« Reply #7 on: August 19, 2009, 08:52:49 am »
