Poll
Do you have a chassis replacement?
nanao spare parts
0 (0%)
rodotron chassis
0 (0%)
Total Members Voted: 0
Author Topic: Chassis replacement for Nanao MS2934S  (Read 4541 times)
fmartine
  • Last login:November 30, 2020, 10:28:35 am
« on: May 14, 2009, 06:51:32 am »
Hi all,
i need a chassis replacement for my monitor arcade Nanao MS2934S,
i read that rodotron 666B could be usesd as replacement ,
do you know if is true?
Do you know where i can buy original one or rodotron replacement?
Do you have any used chassis perfect working?
grettings
Francesco
fmartine74(at)gmail(dot)com
grantspain
Re: Chassis replacement for Nanao MS2934S
« Reply #1 on: May 14, 2009, 02:39:49 pm »
the rodotron 666b1 chassis should work,i tried one on a ms2932 with reasonable results.
the ms2934 should use the same yoke but you should double check
http://home.netvigator.com/~cosmicco/partslist.htm
finding an original chassis will be difficult to say the least
fmartine
« Reply #2 on: May 15, 2009, 03:19:07 am »
ok, thanks for your response,
do you know exactly what do i have to modify?
grantspain
« Reply #3 on: May 15, 2009, 05:10:10 am »
nothing really,maybe a few connectors
fmartine
« Reply #4 on: May 15, 2009, 07:13:05 am »
Do you know where i can buy rodotron chassis?
thanks for your help
grantspain
« Reply #5 on: May 15, 2009, 02:15:10 pm »
yes from the link i gave you earlier in the post---its where i got mine from
