Author Topic: STAR TREK VOYAGER sitdown with green only monitor?  (Read 3232 times)
Lilwolf
« on: May 07, 2009, 09:19:33 pm »
Someone has one for cheap pretty close to me... I would love to get it, but I would pass if the monitor wasn't fixable.  Anyone with a guess what it could / probably is?  I haven't driven over to see it yet.. (but don't know what to look for... and if I fix it on site, he would probably double the cost).
Any suggestions?  should I scrap the idea?
Kevin Mullins
    • Me on Myspace
Re: STAR TREK VOYAGER sitdown with green only monitor?
« Reply #1 on: May 07, 2009, 09:31:39 pm »
In my opinion ..... ANY monitor is "fixable".
The major concern is to know if it's a green screen only because the game is not playing.
In other words, that would be a boardset problem.
So does the game play "blind" ?
Can you coin it up and hear it playing , etc. ?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: May 07, 2009, 10:07:43 pm »
define  " cheap"   ;D
most material things can be repaired or replaced given enough time/money
may also help to know if any retrace lines present ... ?
qrz
supadave
  • Last login:June 11, 2023, 09:10:08 pm
« Reply #3 on: May 08, 2009, 12:17:10 pm »
You must live close to me Lilwolf, cause I've seen the same machine for sale.. hehe..
The seller says everything works but the screen is green..
http://cincinnati.craigslist.org/ele/1157558472.html
Level42
« Reply #4 on: May 11, 2009, 12:55:20 pm »
Usually when "joe average" says the screen is looking "green" it means the red canon/color is not working. Could be anything from a bad connection (likely) to a defective electron gun (unlikely, esp. since it's a relatively recent cab).
Damn I love the side-art of that cab.......really don't know why though ;)
« Last Edit: May 11, 2009, 12:57:58 pm by Level42 »
Kevin Mullins
    • Me on Myspace
« Reply #5 on: May 11, 2009, 01:56:53 pm »
Me either .....    :laugh2:
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #6 on: May 11, 2009, 03:25:49 pm »
Could also be because the green drive transistor is shorted on.   If it's a K7400/K7500/U2000/U5000 this is extremely likely.  The heat from the red and blue transistors seems to  add to the heat of the middle (green) one, making this happen pretty often.
Siris
  • Last login:Yesterday at 07:56:00 pm
« Reply #7 on: May 12, 2009, 01:09:01 am »
More than likely it's just bad connections in the molex connector on the video harness to the monitor.
They probably used the cheapo press the wire in type. Simple fix pull wire out strip off insulation and press wire back in.
BASS!
  • Just have fun.
« Reply #8 on: May 12, 2009, 05:19:41 am »
So did you end up getting it, or did you let it slip through your sweaty little fingers ;)
supadave
« Reply #9 on: May 12, 2009, 11:28:36 am »
I seen one at a local walmart yesterday. I got a closer look at one. Damn thing is huge! also the monitor is huge! looked like a 36" tube or something..  Basic shooter game..
BASS!
  • Just have fun.
« Reply #10 on: May 12, 2009, 07:51:11 pm »
I think its actually a 42"
MonMotha
« Reply #11 on: May 12, 2009, 07:54:04 pm »
I seem to recall that those cabinets had projection monitors (RP CRT) in them, not direct view.
Projection sets are a little more complicated, but still usually reparable aside from the inevitable burn.
shadowolph
  • Last login:May 02, 2011, 01:35:36 pm
« Reply #12 on: November 30, 2009, 08:51:46 am »
I had the same problem with my Star Trek Voyager, I called Wells Garner and told them what it was doing, I thought it was a cap kit problem. they told me that there was a bad part at location so n so on the neck board. I ordered a new neck board from them, for $70 or so and that fixed the problem,
