Author Topic: Lusid cabinet project--reducing the control panel size  (Read 1706 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: May 05, 2009, 11:37:42 pm »
Hi all.  I'm coming into possession of a lusid based cabinet from here  http://www.lusid.net/arcade/.  I'd like to put a slightly less wide control panel on there.  Has anyone done this?  It's a great idea, but I'm only interested in putting on 2 sticks, 6 buttons per player, and the 1 and 2 player buttons.
DrFrag
  • Last login:December 15, 2011, 10:14:47 am
    • MAME Cab Worklog
Re: Lusid cabinet project--reducing the control panel size
« Reply #1 on: May 06, 2009, 10:10:46 pm »
I was looking at the lusid plans when I built my cab, but ended up working from the elvis plans instead.  I only wanted 2 sticks, 6 buttons per player, and credit/start buttons.  They fit comfortably into a 60cm wide control panel (23.6") so you shouldn't have any problem making lusid's panel smaller.  I believe the lusid design is 26" wide, so you could make it without any overhang.
iscariot
« Reply #2 on: May 07, 2009, 08:49:23 am »
My problem is that I'm just trying to reduce an existing panel.  So far I'm having to go off pictures but hopefully that will change.  Does anyone have a printable template for a joystick and 6 buttons a la street fighter II so I can lay out my panel better?
Franco B
« Reply #3 on: May 07, 2009, 11:46:47 am »
There are lots of printable layouts [here]. The 1st one is the Capcom SF layout.
