Author Topic: What is the difference between a Gamelist and a Tree?  (Read 2071 times)
« on: May 01, 2009, 01:06:21 pm »
Just curious.  I'm guessing a tree is like a folder structure and you can have multiple gamelists for each emulator or something?
I've never played around with the tree function before - is it easy to set up?
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
Re: What is the difference between a Gamelist and a Tree?
« Reply #1 on: May 01, 2009, 02:28:40 pm »
Exactly.  The mala tree is just like your windows folder structure, which IMHO results in a clean presentation for the frontend.
The setup is no difficult.  Just open the tree editor and start creating nodes (folders) and gamelist (you associate the tree gamelist to an existing one).   What might result a bit difficult at first is the name convention for the tree snaps, but the learning curve is small.
Just don't forget to check the "Use Tree" option under the GUI tab (I'm at work now, so I don't recall the exact name of the option).
Hope this helps.
I really love the mala tree, it's a great feature in mala.
Cheers, :cheers:
Congui.
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
« Reply #2 on: May 01, 2009, 07:46:14 pm »
I use the tree and love it, once you get the hang of it its easy to setup and simple to use.
check here
http://forum.arcadecontrols.com/index.php?topic=90917.0
loadman
    • MaLa
