Author Topic: Mortal Kombat Jamma Help  (Read 2553 times)
Luige11
  • Last login:December 16, 2009, 11:49:40 pm
« on: April 29, 2009, 10:11:51 pm »
I bought a Mk2 jamma board for my arcade. I connect the jamma connector to the board plug in the sound card etc I know have a hanging wire that connects no where and the lp and lk don't work. So know I have No Sound No Low Punch and No Low Kick. So how would i get this to work.
Kevin Mullins
    • Me on Myspace
Re: Mortal Kombat Jamma Help
« Reply #1 on: April 30, 2009, 12:44:23 am »
Is your JAMMA wired properly for the -5volts?
« Reply #2 on: April 30, 2009, 07:15:36 am »
low punch and low kick require the kick harness. the sound board requires 2 wires, the data ribbon and the power cable.
pictures would be great
« Reply #3 on: April 30, 2009, 09:20:27 am »
Yeah, the Mortal Kombat games technically are Jamma+, so it'll take a little effort to get the working properly in a normal Jamma cab.
Luige11
« Reply #4 on: April 30, 2009, 11:05:19 am »
Ill be posting a few pics in a few days the guy ended up sending me a mk1 board. So know i have to wait till the mk2 gets here
Luige11
« Reply #5 on: April 30, 2009, 11:08:17 am »
How to i get the -5 volts
Luige11
« Reply #6 on: April 30, 2009, 11:18:39 am »
Im about to buy the kick harness from jammboards.com for 14.99$
« Last Edit: April 30, 2009, 11:21:11 am by Luige11 »
« Reply #7 on: May 01, 2009, 07:17:49 am »
MK1 and MK2 kick harness isnt the same, but MKII,MK3, UMK3. MK4, and WWF do share the same harness
Oni2382
  • Last login:December 07, 2015, 11:00:36 pm
« Reply #8 on: May 24, 2009, 02:47:13 pm »
This was REALLY good to know...I'm getting a UMK3 PCB this Tuesday and I was wondering if MK's used the -5v, because the last thing I want to do is damage the board because of improper wiring.
XBL:Mykungfooizgood
PSN: Mykungfooizgud
Kevin Mullins
    • Me on Myspace
« Reply #9 on: May 24, 2009, 06:08:36 pm »
Just be sure your power supply has the -5v available AND is actually wired into the Jamma harness. A lot of JAMMA games don't use it, so a cheap JAMMA harness or JAMMA cabinet may not have even bothered to wire it.
Not having it wouldn't damage the board....it just won't work correctly. (missing sound, etc)
