Author Topic: vs games  (Read 1863 times)
nd4w
  • Last login:June 22, 2009, 10:50:24 am
vs games
« on: April 24, 2009, 08:36:25 am »
Maybe a easy question, but , how do you start the vs type games when it shows the game on a list and says"enter to start" ?
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
Re: vs games
« Reply #1 on: April 24, 2009, 03:23:24 pm »
I think you're confusing VS games with playchoice games.
Any way.  In playchoice games hit tab and go into the Input (this game) menu and look for for the mapping for the channel select and the enter key;  you can map the enter key to what ever key you like; just make sure they're different.    Also look for the mappings on Game select and Start; they're different to other mame games.
Once you know your mappings here is what you do.  Make sure the game you want is selected (only one in the top of the list) and hit the enter key; if not use the Channel Select key to do so.  Use the Game Select key to choose the game option and then hit the Start key.  Thats it.
Hope this helps.
Cheers, :cheers:
Congui
nd4w
Re: vs games
« Reply #2 on: April 24, 2009, 05:28:18 pm »
Thanks, yes play choice is what I meant. I got it to start.
Thanks alot
Mike
