Author Topic: UH, What did I do? Monitor died  (Read 2017 times)
Hoagie_one
  • Um....whats a cabinet
« on: April 24, 2009, 01:40:43 am »
Jamma cab with jpac + arcade VGA
Just got the new mame cab set up and I was messing with the h-hold to try to get some more real estate on the monitor.  I turned the h-hold knob a little far to the right.  I got a scrambled picture, then a squeal, then the monitor died.  It wont power up now.
What Did I do and how can I fix it?
SirPeale
  • Green Mountain Man
Re: UH, What did I do? Monitor died
« Reply #1 on: April 24, 2009, 01:40:38 pm »
Make/model of the monitor in question?
Turn the H hold back all the way and power it back up.  I have a monitor that does the same thing.
Hoagie_one
« Reply #2 on: April 24, 2009, 02:13:25 pm »
Yeah, this morningI turned it back and it started right up.
I thought i toasted it.
SirPeale
« Reply #3 on: April 24, 2009, 06:08:29 pm »
Nope, you just triggered the protection circuit.  Scary at first though...isn't it?
Hoagie_one
« Reply #4 on: April 25, 2009, 10:07:30 pm »
f'real
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #5 on: April 25, 2009, 11:06:13 pm »
RCA had a chassis that the hfreq could be pulled off far enough to trigger shutdown.
the "fun " part was everything was menu driven. the set had to operate to adjust anything.
only way to restart under that condition , was to detune the h output ( add a cap to hot) then adjust h freq.
sometimse, had to do so with a severly corrupted eeprom..... (ctc177 )
qrz
