February 25, 2026, 07:17:19 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Main
Monitor/Video Forum
Wells K7400 Vertical Deflection Problem (pics Included)
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Wells K7400 Vertical Deflection Problem (pics Included) (Read 4323 times)
powerplay
Trade Count:
0
Full Member
Offline
Last login:December 15, 2009, 02:58:54 pm
on:
April 22, 2009, 01:48:55 pm »
This is a Wells Gardner K7400 (P763). I have a Horizontal line in the middle of the screen. I have replaced many components which I will list. Most of these usually do the job to fix this problem but, I haven't had any luck. Here's the list:
D302
R402
U601 (Ic, Vertical Deflection)
U701
R303
T700 (FLyback)
D603
R627
C610
C603
I have also replaced the control board just in case along with a cable. Tried another joke as well. All the above parts were replaced with new parts and all the parts mentioned on this paragraph were reinstalled on a working chassis to make sure they work and they do. I am getting my+25V to my U601 pin 9 as required. After all that still the same as the pictured included.
Any help is appreciate it. thanks
Model of chassis
http://i687.photobucket.com/albums/vv234/Powerplay800/k7400-1.jpg
Error on screen
http://i687.photobucket.com/albums/vv234/Powerplay800/k7400-2.jpg
Logged
qrz
Trade Count:
+1
Full Member
Offline
Last login:October 24, 2015, 03:04:15 pm
wrangling electrons since 1978
Re: Wells K7400 Vertical Deflection Problem (pics Included)
Reply #1 on:
April 22, 2009, 06:08:51 pm »
also check q602 for leakage or ce short.
and check c613, c616, c614 and r618, r613
qrz
Logged
powerplay
Trade Count:
0
Full Member
Offline
Reply #2 on:
April 30, 2009, 09:04:56 am »
Thanks for all the help QRZ but still no change. I replaced Q602, C613, c616, c614 and r618, r613 as you mentioned, and no luck. i still have the same line. Anything else I should look at?
Logged
Kevin Mullins
Trade Count:
+2
Full Member
Offline
Last login:February 01, 2021, 01:29:34 pm
Reply #3 on:
April 30, 2009, 02:15:41 pm »
I'm going to assume you've checked for obvious bad solder joints around the yoke pins and the yoke itself right?
Logged
powerplay
Trade Count:
0
Full Member
Offline
Reply #4 on:
April 30, 2009, 04:04:43 pm »
kevin, you got it!, I sure have. I think i can do a tatoo of this board on someone as many times I have seen it and gone over it lol. Yeah i done all that and still no luck.
Logged
qrz
Trade Count:
+1
Full Member
Offline
Reply #5 on:
April 30, 2009, 09:46:22 pm »
try another output ic .
be cautious on your vendor. many counterfeit semiconductors are beginning to surface
qrz
Logged
cgaw69
Trade Count:
0
Jr. Member
Offline
Last login:December 16, 2022, 03:55:23 pm
Reply #6 on:
April 30, 2009, 11:12:00 pm »
Does your monitor have a remote adjustment board? I have a Kortek 25 in. that had remote adjustments and that the person before me installed it backwards on the extension cable. Resulted in the exact same condition you pictured. Not saying this is the case with yours. Just thought the info might help.
Logged
Kevin Mullins
Trade Count:
+2
Full Member
Offline
Reply #7 on:
May 01, 2009, 12:03:54 am »
I was going to suggest looking at the remote board or vertical pots as well.
Could have a bad or broken potentiometer.
Just another easy thing to check.
Logged
qrz
Trade Count:
+1
Full Member
Offline
Reply #8 on:
May 01, 2009, 12:48:56 am »
good point Kevin. vert deflection is a "closed loop" .
which is why signal injection isn't an effective troubleshooting method in this stage .
a fault in the feedback loop , or elsewhere , will cause problems .
def have a look at the size/linearity pots. it might just be that simple.
qrz
Logged
powerplay
Trade Count:
0
Full Member
Offline
Reply #9 on:
May 01, 2009, 09:57:49 am »
Thanks for the feedback guys.....but as stated in my initial post, paragraph after the list of components changed I put:
"I have also replaced the control board just in case along with a cable. Tried another joke as well. All the above parts were replaced with new parts and all the parts mentioned on this paragraph were reinstalled on a working chassis to make sure they work and they do. I am getting my+25V to my U601 pin 9 as required."
The control board was put in another monitor board chassis and it works, I have also tried another one just in case from a working monitor board and still no luck. i will try another output ic and i will let you guys know.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
