Author Topic: virtua cop 2 refuses to run  (Read 2390 times)
reko19
  • Last login:July 16, 2025, 10:06:10 am
« on: April 22, 2009, 08:33:32 am »
Hi,
Trying to run virtua cop 2, crashes and refuses to start. I get a typical BS error message from Windows XP. Runs fine on other computer. I am using Arcade Vga, could this cause a problem?  Any suggestions? I am about to give up on it. Thanks.
« Last Edit: April 22, 2009, 08:41:03 am by reko19 »
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
Re: virtua cop 2 refuses to run
« Reply #1 on: April 22, 2009, 09:43:49 am »
Getting a blue screen when running a game? I'd check drivers first then start looking at hardware.
reko19
« Reply #2 on: April 22, 2009, 09:58:01 am »
can't even start a game, gives me an error before it even starts. I could post a picture of the error screen tonight. What drivers should I be looking at? Everything else works fine including PC games like HOTD, Mad Dog, etc.
severdhed
  • Last login:November 08, 2025, 10:49:16 pm
  • RIP Dinosaur Hippo
« Reply #3 on: April 22, 2009, 01:12:58 pm »
did you look in the event log to see if there is an entry created when it crashes?  if so, the information in that error message may be helpful.
reko19
« Reply #4 on: April 22, 2009, 01:25:11 pm »
good idea, will report tonight
reko19
« Reply #5 on: April 22, 2009, 08:50:17 pm »
OK, I don't think there is a log file, error msg is attached. Any ideas?
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
« Reply #6 on: April 22, 2009, 08:53:45 pm »
PC version yes?
reko19
« Reply #7 on: April 22, 2009, 09:14:32 pm »
yep, running on XP
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #8 on: April 22, 2009, 09:37:18 pm »
Wikipedia reports that Virtua Cop 1+2 have problems running correctly (particularly with a lightgun) under Windows XP. Try getting your hands on the Japanese versions called Virtua Squad 1+2, which is what I had to do and they run fine.
reko19
« Reply #9 on: April 23, 2009, 08:01:04 am »
thank you, I googled this to death but somehow this did not come up. will proceed accordingly.
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
« Reply #10 on: April 23, 2009, 02:41:36 pm »
I wondered why I keep seeing "Virtua Squad" all over the net.
swamprat96
« Reply #11 on: May 04, 2009, 01:55:52 am »
reko19- run the .exe under windows98 compatibility. Right click the icon select properties/compatibility tab and selct windows98
