Author Topic: cheat problem  (Read 2503 times)
mr_doles
  • Last login:November 25, 2025, 08:42:10 am
  • nuff said
cheat problem
« on: April 19, 2009, 02:54:29 pm »
For the past 3 days I have been trying to get the cheats working on my Mame machine.  I have read every article here, the mamecheat website and googled the heck out of it.  I am missing something but I can't figure it out.  :banghead:
I have the cheat.zip (for use with .130u2 which is the newest one out there) in the correct spot.  The mame.ini has been modified correctly.  When I run a game (that I did verify has a cheat in the xml file) I get error parsing cheat expression "maincpu.pb@xxxxxx=xx (the x's change per game).  I know Mame sees the xml as the maincpu.pb is listed in the action xml node in the xml file.
The only thing that I can think is that I need to have a cheat.zip designed for .128 and not .130u2.  If that is the case I find no mention of one existing.
Please tell me I am doing something simple wrong here.
EDIT: If it matters I am running version .128 with the hiscore diff applied.
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Re: cheat problem
« Reply #1 on: April 19, 2009, 02:57:16 pm »
try going into the mame.ini and seeing if it on should be a 1 not 0
mr_doles
  • nuff said
Re: cheat problem
« Reply #2 on: April 19, 2009, 03:12:09 pm »
Yes it is set to 1 in the mame.ini file.  It has to be set up correctly because Mame does read the xml file I keep getting the parse error on all the games.
wooowman93
Re: cheat problem
« Reply #3 on: April 19, 2009, 03:27:36 pm »
than i have no clue maybe try another version of Mame, Mame plus works good
mr_doles
  • nuff said
Re: cheat problem
« Reply #4 on: April 19, 2009, 03:32:44 pm »
Yeah I got this one working the way I want it too (except for the cheat part), really don't want to setup everything again just for that.  Anyone else got any suggestions?  Was there a cheat.zip for .128?  Is anyone using .128 with the cheats turned on?
mr_doles
  • nuff said
Re: cheat problem [SOLVED - Sort of]
« Reply #5 on: April 20, 2009, 04:24:25 pm »
From www.mamecheat.co.uk
The 0.130u2 XML cheat collection won't work with MAME 0.128, there was a major change in 0.129u5 which is what you are seeing.
You should upgrade to 0.130u4.
Don't want to upgrade as it will break some of my games so I guess I don't get to use this then.  :hissy:
