Author Topic: Load a generic image if no image is present. Is there a way?  (Read 3011 times)
blkdog7
  • Last login:October 07, 2015, 04:43:38 pm
  • Mushroom Kingdom, MA
    • John's Arcade
« on: April 18, 2009, 08:57:36 pm »
I am displaying Marquees instead of text in MALA and as you know, not all marquees are available. Is there a way to load a generic marquee image if no image is present? Anyone know?
loadman
    • MaLa
Re: Load a generic image if no image is present. Is there a way?
« Reply #1 on: April 18, 2009, 09:21:19 pm »
Yes, You specify it using the Layout Editor
blkdog7
    • John's Arcade
« Reply #2 on: April 18, 2009, 09:49:12 pm »
Oh, great! Can you explain more?
loadman
    • MaLa
« Reply #3 on: April 18, 2009, 10:43:42 pm »
In the editor, select the object, select properties then at the top of the properties window you have the option of setting a default image.
blkdog7
    • John's Arcade
« Reply #4 on: April 19, 2009, 01:27:37 pm »
Ok, I added a default image in the editor and it didn't work. Any ideas?
blkdog7
    • John's Arcade
« Reply #5 on: April 19, 2009, 01:33:10 pm »
Figured it out! The image needs to be in the layout folder.
THANKS TONS!
