Author Topic: WTB 25" WG 7000 Chassis [St. Paul, MN]  (Read 2169 times)
atomikbohm
  • Last login:January 22, 2018, 11:33:35 am
« on: April 17, 2009, 06:30:40 pm »
I got a great NFL Blitz Cab includeing the control pannel, coin mechs, Jamma harness, 49 way sticks, monitor bezel and a 25" tube with no burn in!!!! You can see where this is going ... right?
Anyone have a WG 7000 Chassis they would be willing to part with?  Please ???
I think I have the iso, power source, degaussing ect. covered.
« Last Edit: April 20, 2009, 04:04:52 pm by atomikbohm »
Rook3
  • Last login:August 07, 2025, 01:40:55 am
  • Greetings Starfighter! You have been recruited...
    • Rook's Castle.com
Re: WTB 25" WG 7000 Chassis [St. Paul, MN]
« Reply #1 on: April 21, 2009, 10:12:59 pm »
Have you tried contacting Lieberman's or any of the other route operators in your area?
Couldn't hurt to try anyway.
Russ
abzman2000
  • Last login:August 26, 2020, 06:25:12 pm
  • I LIKE my hat!
« Reply #2 on: April 21, 2009, 10:35:36 pm »
I think I can get you a schematic and bob roberts has the 3 specialized ICs and the flyback that are the only parts not available at jameco or on digikey if you want to try and build a chassis yourself.  I know it sounds crazy, but I really want to see someone try it.
atomikbohm
« Reply #3 on: April 22, 2009, 12:34:35 pm »
Build my own chassis ... I'm going to have to take a look into that.  I'm just inexperienced, naive and stupid/crazy/cheep enough to seriously consider it.  >:D  I'm gonna do some research.
But, I'm also gonna do some price and availability research with Lieberman's too.   ;D
Thanks for the suggestion and possibly suicidal project suggestion.
I'll keep you all posted.
abzman2000
  • I LIKE my hat!
« Reply #4 on: April 22, 2009, 01:26:28 pm »
therealbobroberts.com has:
WG K7000 Flyback OEM $45.00
WG K7000 Flyback Replacement   $19.00
WG K7000 Flyback Repair Kit  $26.00
WG K7000 Horizontal width coil 009A2854-001  $12.50
WG K7000 Cap Kit $6.00
WG K7000 HOT 2SD1398 $5.00
WG K7000 Regulator IC4 STRxxxx most popular are:
19" chassis = STR3123 or STR30123
25" chassis = STR3130 or STR30130 $5.00
WG K7000 Retrace Cap (Critical Safety Cap C36) $6.00
WG K7000 Capacitor C38 .39uf 200v $5.00
WG K7000 IC1 UPC1397 $10.00
WG K7000 IC2 LA7823 $6.00
WG K7000 IC3 UPC1378 $11.00
WG K7000 R103 2.7 Ohm 7W Resistor $1.00
and here is a schematic (k7191):
http://jstookey.com/arcade/WG_25k7191/
the ICs on the schematic are on the list of k7000 series parts available from bob
atomikbohm
« Reply #5 on: April 29, 2009, 01:29:49 pm »
Lieberman's was a bust they don't have a parts department any longer.  They have a Happs supplier on site now but they don't carry K7000 Chassis.   :banghead:
Still looking for a chassis, preferably working but if cheep enough I'll consider a non working (I really don't want to have to manufacture a PCB to mount all of the components to, and if any of the original parts work all the better for my wallet!!!)
