Author Topic: Cost of a light gun set-up?  (Read 2310 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
« on: April 15, 2009, 06:11:57 pm »
I was wondering how much it would cost to have two light guns fully working?
and if it's worth putting into a cabinet
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
Re: Cost of a light gun set-up?
« Reply #1 on: April 15, 2009, 07:11:47 pm »
That would depend on what guns you buy, what display you're running and how you're feeding the signal to that display.
wooowman93
« Reply #2 on: April 15, 2009, 07:20:21 pm »
Ok, lets say it a TV(tube) with s-video and im not to sure what guns there are :dunno
DJ_Izumi
« Reply #3 on: April 15, 2009, 07:57:22 pm »
If you're using S-Video, the Guncon2 is probably your cheapest bet and there are drivers for'em.  IN that situation, you'd meerly need to split the S-video into a composite adaptor and let that go into the Guncon's video jacks.  Guncons go for $10-$20 used.
swamprat96
  • Last login:January 10, 2012, 03:29:46 pm
« Reply #4 on: April 17, 2009, 05:49:12 pm »
Be wary here. You'd want a nice bright CRT monitor. I tried this with an arcade monitor and it never worked well. There are two posters here that have made it work with TV's using the TV's own TV out. There are no documented success stories with arcade monitors that I can find.
I tried everything. The best I ever got was mediocre tracking and only on games with light backgrounds. I'm using topguns now which I think is the best on the market currently but by no means perfect. Others have had luck with ACT light guns but there are some who have not.
JayB
  • Last login:January 25, 2013, 06:11:59 pm
« Reply #5 on: April 17, 2009, 06:12:41 pm »
I have a Guncon limited edition from years back but, it has PS One connector and a couple of rca jacks. Would that be possible to get it setup somehow?
I also have the proper Red/Blue Happ guns that came with my machine although are not connected right now. Any luck with these running under Mame with a TV screen?
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #6 on: April 17, 2009, 07:56:23 pm »
Not yet, but this could be promising.
Haven't heard anything in a while though.
Working: Not Enough
Projects: Too Many
Progress: None
BobA
  • What Me Worry?
« Reply #7 on: April 17, 2009, 08:19:38 pm »
2 act lab interfaces and 2 guns about $180.   Interfaces depend on TV CRT or VGA monitor choice.
DJ_Izumi
« Reply #8 on: April 17, 2009, 08:22:04 pm »
:O  Do you mean the LE Elemental Gearbolt gold plated Guncon that only 50 were ever produced and only 3 known copies exist?
Cause if so, that's worth a BIT of money and you might not wanna be up and jury rigging it to an arcade rig.  That's the only LE Guncon I know of. :)
Anyway, no, to my knowledge there is no adaptor or driver for the Guncon 1 to make it work on a PC, not that you probably couldn't build one, it'd be a LOT of work.  The Guncon 2 for PS2 on the other hand is already USB based so they only needed to make a PC driver for it and voila.
