Author Topic: AtomicFE Ult question  (Read 1456 times)
clok
  • Last login:April 03, 2018, 10:58:39 pm
  • I can play PacMan till the screen splits!
« on: April 15, 2009, 01:01:55 pm »
Anybody install the ultimate set for Atomic FE? I recently did (30 minutes ago) and everything is french (i think), i even uninstalled and made sure i checked the "english" setting. Is there some simple way to get this to engish? Can i just install Atmomic FE over my install? Or is there some setting i can change?
HELP!!!  :)
youki
  • Atomic Front End Creator
    • Atomic Front End
Re: AtomicFE Ult question
« Reply #1 on: April 15, 2009, 03:25:50 pm »
Hi,
Normally you have the choice at the installation i think.  I didn't install it recently (i'm not the author of this distribution) , and i know ladite is updating it regulary.
i will ask him.
But if you have specific question about that distribution please post on the official thread of the support forum here :
http://spaceinvaders.7.forumer.com/viewtopic.php?t=1186
You will have faster anwser.
If you install AtomicFE other your installation it won't change the language in that case.
Anyway i"m going to contact the author, he will know what to do.
clok
« Reply #2 on: April 15, 2009, 04:02:08 pm »
Yes when installing it give two options for language, fench and English, but no matter what i pick i get french it seems. I have registered for that board, but not active yet so posted here.  Thanks for quick reply. actually tried again, still same problem. The page i downloaded it from was all english, possibly i downloaded the wrong one?
youki
    • Atomic Front End
« Reply #3 on: April 15, 2009, 06:26:14 pm »
no, i think you download the right one, there is only one full install. Other are just individual modules.
But my be he didn't translate screens.
I sent him a message. If he is not in vacation , he will answer you for sure.
clok
« Reply #4 on: April 17, 2009, 12:49:29 pm »
 :notworthy:Youki  :notworthy: found my problem and has offered a solution in the offical forums.
Once again OUTSTANDING support!!!! once I'm all setup you can count on a donation!!!!!
So this one is closed and fixed (it was a config file in french).
