Author Topic: MiniPac - How to assign shift key? [SOLVED!]  (Read 1763 times)
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
« on: April 14, 2009, 01:01:16 pm »
Hey guys,
Does anyone know how I assign the shift function to a switch/port on the MiniPAC? By default it is assigned to (physical switch) 1PSTART, but I have wired my panel differently and I would therefore like to assign the shift function to another switch (e.g. P2SW5).
I have tried using both the WinIpac IPD util and the text-util, but I can't see how or where I assign a new shift-key (other than the default 1PSTART switch). Can anyone help me out here? :) Thanks in advance.
« Last Edit: April 14, 2009, 03:19:32 pm by dekar24k »
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: MiniPac - How to assign shift key?
« Reply #1 on: April 14, 2009, 02:15:20 pm »
Sure. If you go to the table view, the shift key is shown at the top in a yellow box.
Just click and re-assign by clicking on an already-assigned button on the table.
dekar24k
    • ArcadeForum.com
« Reply #2 on: April 14, 2009, 02:19:51 pm »
Ah! So I click the yellow shift-box, then I click one of the switches on the table and not on the physical control panel (buttons)? Thanks a lot, I will try that out right now. :)
dekar24k
    • ArcadeForum.com
Re: MiniPac - How to assign shift key? [SOLVED!]
« Reply #3 on: April 14, 2009, 03:19:43 pm »
Worked perfectly. Thanks again! ;)
surface tension
« Reply #4 on: April 14, 2009, 03:34:19 pm »
No problem :)
