Author Topic: 2005 golden tee help!!!!  (Read 8424 times)
DON SHAGWELL
  • Last login:November 02, 2009, 06:05:53 pm
« on: April 13, 2009, 10:32:39 am »
So I picked up on 05 machine and once it was plugged in it goes into start up and loops over and over and never goes to the game. Any ideas???
Thanks for your time
Ken Layton
  • Guru
  • Technician
Re: 2005 golden tee help!!!!
« Reply #1 on: April 13, 2009, 10:55:16 am »
Contact tech support at the manufacturer www.itsgames.com
DON SHAGWELL
« Reply #2 on: April 13, 2009, 11:40:42 am »
Thank you for the info :applaud:
DON SHAGWELL
« Reply #3 on: April 13, 2009, 04:24:21 pm »
I.t. could not help, if it's the main board is there any switches or plugs that I can mess with? I did notice 2 female plugs not plugged into anything and at the bottom of the machine 1 male. Has anyone else had this problem?
TOK
  • The Game Always Wins
« Reply #4 on: April 13, 2009, 08:44:13 pm »
There are harness plugs for a few things like the dollar bill acceptor, players card and remote admin switches that don't need to be connected for the game to operate.
Do you get a message saying the voltage is low on the diagnostic screen before it cycles?
Next thing I'd try is the hard drive. You can get a tested hard drive from an ebay seller named arcademojo... I bought one as a spare, though I haven't tried it.
DON SHAGWELL
« Reply #5 on: April 13, 2009, 09:14:52 pm »
So when it runs through it's test everything says pass but
NO MODEM
SIGN PORT ( FAILED )
BOARD TEST  ( FAILED )
Everything else says pass, I have 3 blinking lights. 2 blink green and 1 blinks red.  Being a newb that's what I got so far.
TOK
« Reply #6 on: April 13, 2009, 09:58:51 pm »
Do you have a manual? I have the manual in PDF form, but its about 5 meg. If you're able to PM me an e-mail address that will handle large attachments, I'll send it over.
If you don't, and want to verify the DIP settings are correct here is the info. Most of this doesn't apply to the problem you're having, but you can get into the operator menu and stop the machine from trying to dial out to ITNET. That might eliminate the modem error.
SW51-Dip switches found on the main PCB near the JAMMA connector
Dip 1 (ON)  Normal Play (Default)
Dip 1 (OFF) Operator mode
Dip 2 (ON) ALWAYS ON
Dip 3 (ON) ALWAYS ON
Dip 4 (ON) ALWAYS ON
The SW5-Dip switches can be found near the flashing green LED. These are used to adjust monitor resolution.
Dip 1 (OFF) Medium Resolution (DEFAULT)
Dip 1 (ON)  Low/Standard Resolution
Dip 2 (OFF) Low Resolution B Adjust (if you have jittery images, switch this)
Dip 2 (ON)  Low Resolution A
DON SHAGWELL
« Reply #7 on: April 17, 2009, 04:20:10 pm »
Thanks for the help, I ordered a hard drive and will be in monday.
DON SHAGWELL
« Reply #8 on: April 22, 2009, 01:25:42 pm »
The hard drive was the issue, one last question.   Is there a way to erase the memory to get rid of the previous scores?  Thanks again
TOK
« Reply #9 on: April 23, 2009, 05:54:47 am »
Yes... There is a spot in the operator menu. You have to do it for each course.
There are a couple things you can't change, one of them is the games "location". My GT thinks its somewhere in CT.
hatrick
  • Last login:January 23, 2020, 12:47:20 pm
  • Big Brother is Watching You!
« Reply #10 on: April 29, 2009, 02:39:51 pm »
If only someone could figure how to hack this. My 2004 is convinced it is in Indiana.
