Author Topic: got chassis back ++++problem solved+++++  (Read 2213 times)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« on: April 07, 2009, 10:41:29 pm »
got my chassis back from a cap kit and now you can hear a hissing noise from the black box that its between the flyback transforemr and the anode cap the box has a ground or a black wire coming fom it but --BINGO! Either that, or I was attempting to say "before" but it was too many letters to type-- it never was hooked up  before i had a cap kit installed , its still not hooked up to anything now cause i dont want to ground it and mess something upand i  dont want to fry anything but if you put any metal near it, it will jolt some electricity the picture on the monitor is fine just this one problem and i dont know what to do any advise its a wg u2000 chassis and a wg tube hears a video fo the box and some of the noise if u can hear it
« Last Edit: April 08, 2009, 10:15:41 pm by adidas1984x »
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: got chassis back and now hear a hissing oise and can see sparks
« Reply #1 on: April 07, 2009, 11:00:28 pm »
That wire gets hooked up to the frame of your monitor.
adidas1984x
« Reply #2 on: April 08, 2009, 05:14:18 am »
it was not hookep up before and didnt make any noises or spark and im afraid it will pop the chassis or the frame will pop m then
Kevin Mullins
    • Me on Myspace
« Reply #3 on: April 08, 2009, 10:58:42 am »
adidas1984x
« Reply #4 on: April 08, 2009, 11:16:19 am »
would you suggest covering it up in eletrical tape or, if i ground it like that will it short the chassis or make the frame hott and shock me if i touch the frame
