Author Topic: Can you mount a trackball turned 90 degrees?  (Read 1559 times)
Triangel7D
  • Last login:September 10, 2017, 01:06:09 pm
« on: April 06, 2009, 09:44:26 am »
Hi everyone. Longtime lurker, first time poster.
I'm building my first cabinet (finally) which is a conversion of an old 19" Taito cabinet and it came with a Happ 3" trackball. This sucker is HUGE underneath the CP, and I'd like to build a new CP with a 7-button per player setup and spinner.  The CP (at the moment) is only 23" across, and I need all the room I can get.
Would it be possible to mount the trackball at a a 90 degree angle to allow for more room? Wouldn't I just switch the axises to the Mini-Pac?
severdhed
  • RIP Dinosaur Hippo
Re: Can you mount a trackball turned 90 degrees?
« Reply #1 on: April 06, 2009, 09:50:49 am »
yeah..you would just need to change the wires to make sure the x and y axis are working properly after the rotation
RandyT
  • Last login:Yesterday at 08:50:34 am
    • GroovyGameGear.com
« Reply #2 on: April 06, 2009, 01:07:10 pm »
You can change the orientation of a trackball, but you have to keep in mind that they tend to work a little better in some direction than others, due to the physics involved with the way the rollers are placed.
For instance, games which require a hard forward spin may not work as well when the TB is rotated.
RandyT
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: April 07, 2009, 03:18:22 pm »
Yup, depending if it's being rotated left (aka clockwise) or right.  If there's a roller still at the top after it's rotated, it'll be fine (with the referred to golf/bowling/horseshoe games).  IOW, rotating left is fine OTTOMH (I'm sure of happs, and pretty sure about all others).
Robin
Knowledge is Power
