Author Topic: Mcdonalds, monitor for jukebox  (Read 3117 times)
rock66
  • Last login:April 13, 2009, 06:45:58 pm
« on: April 06, 2009, 07:31:33 am »
I just picked up a nexdisplay-4 monitor that was from a mcdonalds.has any one  used this monitor to make a jukebox and if so where did they get the drivers.I have searched the internet for info on this model and the only other info I have is its from electronic systems services. thanks
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
Re: Mcdonalds, monitor for jukebox
« Reply #1 on: April 06, 2009, 11:19:56 am »
Are you sure the touchscreen part is not from ELO or another touchscreen company. I did a google of nexdisplay-4  and got nexdisplay-4  is a POS software company - that doesnt mean the actual touchscreen (piece of glass on top of the lcd) is from them.
When you plug it into your pc, does the monitor work? If so, then that is half the battle.
Then is the touchscreen USB or Serial?
Plug that in to see if Windows (or other OS) automatically finds it.
If that doesnt work, download PC Wizard http://www.cpuid.com/pcwizard.php and if your touchscreen is plugged in through USB or Serial, the PC Wizard will tell you the manufacturer of the touchscreen. :)
Hope that helps and gets you in the right direction!
Fordman
Fordman
  • MADE in the USA
« Reply #2 on: April 06, 2009, 11:34:37 am »
Upon futher searching, I found this for you also. The touchscreen you have is from ELO!
Tha manufacturer of the equipment you have is Javelin but uses an ELO touchscreen.
http://www.jvln.com.au/index.html
http://www.jvln.com.au/downloads/touchscreens/Javelin120LCD/120lcd.html <--- Driver for your touchscreen here 2.8mb for Win XP - 2000. Also ther is a manual for download too!
Now you have to find out if you have a Javelin 120 LCD or a Javelin POP LCD. By looking at the file being downloaded, it is the same file so the driver you downoad for either 120 or POP should work with your monitor
Hope that helps!  :cheers:
Fordman
« Last Edit: April 06, 2009, 11:37:58 am by Fordman »
rock66
« Reply #3 on: April 07, 2009, 08:16:35 am »
thank you for the reply,I am waiting to pick up a power supply. will keep in touch on my progress. Thanks
rock66
« Reply #4 on: April 10, 2009, 10:53:36 pm »
Ineed to find a power supply with a 4 pin round jack ,help any one Thanks
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #5 on: April 11, 2009, 04:31:09 pm »
A Picture of the socket might help.
