Author Topic: XBOX DIY Arcade Stick HELP and Suggestions  (Read 5345 times)
kandiman
  • Last login:April 13, 2009, 12:40:35 am
« on: March 31, 2009, 03:26:12 am »
Hey all, going to build a arcade stick out of an official xbox 360 wired controller, i will take pictures of the PCB once i get them tomorrow, there will be 2 PCBs.
At the moment i have these parts
6 sanwa 30mm obsf buttons ------  main buttons
2 sanwa 24mm buttons    ----------  start and xbox guide/home
1 sanwa joystick JLF-TP-8YT  ------  joystick has mounting plate attached
1 sanwa joystick Harness    -------  quick connect/disconnect harness for Sanwa JLF joysticks
also bought a bunch of these quick connect wires
http://www.in2amusements.com.au/shop/index.php/13/236_Wire_Coloured_With_Quick_Connector_.110_Size
http://www.in2amusements.com.au/shop/index.php/13/233_Wire_Ground_Harness_Suit_Sanwa
These are the 2 versions of the PCBs which alot of you guys have seen
http://www.slagcoin.com/joystick/pcb_diagrams/360_diagram6.jpg
http://www.slagcoin.com/joystick/pcb_diagrams/360_diagram1.jpg
Based on my parts and the PCB that i get (could be both the early and late version), may someone help me out with a sketch diagram for the hookup of the wires from the buttons to the PCB?
What iv'e read the common ground PCB should/can be daisy chained? no idea how the daisy chain business works.
Any input or suggestions will be awesome  ;D ... please don't flame me and say "search" the forums first  :timebomb:
Franco B
Re: XBOX DIY Arcade Stick HELP and Suggestions
« Reply #1 on: March 31, 2009, 04:03:49 am »
Welcome to the forum.
Well I suppose your expecting this, but seriously, search!
If you took two minutes to search or look around you would see this thread right at the top of the consoles sub-forum
> [Xbox 360 Controller Hack Tutorial -- Wireless Hack Now Available!!!] <
You will find most of what you need in there. Have a good read and then come back if you have any questions.
  • Last login:February 22, 2026, 06:49:16 pm
« Reply #2 on: March 31, 2009, 09:35:35 am »
Yeah, take a look at my tutorial.  While for an Xbox 360 pad, the method is still basically the same.
kandiman
« Reply #3 on: April 01, 2009, 03:06:55 am »
Thanks for the replies  :) .... my bad i shall read the tutorial  ;D
While i'm reading the tutorial, someone explain to me how to do a daisy chain if i have a common ground PCB  :)
Franco B
« Reply #4 on: April 01, 2009, 03:33:35 am »
Daisy chaining means you connect all of the microswitches ground/common terminals together and then attach the linked wire to the common ground on your pad. Kinda like this:
This isn't a control pad but its the same principle. You can see all of the ground/common terminals are linked together whereas the NO (normally open) terminal from each microswitch is attached to a separate input.
Its a good idea to make the chained grounds into a full loop, that way if you ever have a single ground fail the pad will still function.
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #5 on: April 01, 2009, 10:31:52 am »
Heh, another forum another group of people telling you to search.
kandiman
« Reply #6 on: April 02, 2009, 03:28:13 am »
thanks for the diagram makes sense kinda  ;D
I have 2 PCB's someone determine if i have a common ground board?
« Last Edit: April 02, 2009, 03:33:53 am by kandiman »
« Reply #7 on: April 02, 2009, 07:39:54 am »
neither one of those is common ground.
kandiman
« Reply #8 on: April 02, 2009, 08:07:55 am »
yeah i thought so, that sux  :-[
