Author Topic: Simpsons Iso trans wiring?  (Read 2014 times)
ZORK2
  • Last login:May 22, 2010, 11:45:04 pm
« on: March 27, 2009, 02:15:04 pm »
Can anyone out there with a Simpsons cabinate tell me how the wiring is run to the Isloation Transformer(The Trans that goes to the monitor?)  It has 3 inputs from the power supply, and 2 outputs that go to the moniter. The wiring diagram I am using that came with the game is next to useless! THANKS!
Kevin Mullins
    • Me on Myspace
Re: Simpsons Iso trans wiring?
« Reply #1 on: March 27, 2009, 04:05:55 pm »
That's about as simple as a diagram will ever get........
http://forum.arcadecontrols.com/index.php?topic=90944.0
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: March 27, 2009, 04:22:24 pm »
3 in, 2 out is normal.
If this is in regards to your monitor stopping working (and I believe you said a fuse is popping), it's not the transformer. But do check that there is a grounding wire coming from elsewhere, grounding the monitor frame and other parts.
NO MORE!!
ZORK2
« Reply #3 on: March 27, 2009, 04:46:34 pm »
Yeah it is, but was a darn a mess in there! Hard to tell what it what. Someone didn't know what they were doing when they were wiring! What a MESS!! I've traced back most of the wires now, and have things cleaned up!!
