November 30, 2025, 03:40:04 am
bondo is BYOAC's best friend!unlike spacle and woodfiller which are mostly water based, so shrink when they dry. bondo is an epoxy type thing that cures cemically so no shrinking
Quote from: Bender on March 25, 2009, 01:38:51 pmbondo is BYOAC's best friend!unlike spacle and woodfiller which are mostly water based, so shrink when they dry. bondo is an epoxy type thing that cures cemically so no shrinkingGood point. Anyone know of a UK alternative? Idealy from Wickes, B&Q etc
Jav,you can simply put a little less hardner in the mix aand it will take longer to setup. On another note, shouldn't you be finishing that juke before starting another project??
im currently doing some work on a Double Dragon Cab for my brother. It has some bad spots on both sides and with the cab on its side, i cant get to them all at once. so what i do is just mix up a small batch on a piece of card board. fill in the areas i need to and then let it dry. then repeat with a new piece of card board. its not hard to use at all. dont worry if you mix to much the first few times. you can always mix more. after mixing, work for a few minutes on the areas that need work and then stop. clean your tools and let it dry. if you try and work with the bondo when it starts to get tacky, you will not be able to fill in spots very easily.
Just use your belt sander
Bondo filled 27 holes in THIS panel...
Damn Frizzle. Looks like it may have quicker to just make a new one.
