February 11, 2026, 08:42:21 pm
runtime error 9 subscript something or other... =(
From Triggerfins catlist site http://www.mameworld.net/catlist, here are the FE's that support it:Advance MenuArcade@HomeEmulaxianEmu LoaderMAME FEgRustibusGXMameMAMEWAHMAME WizardMCMQuickPlayS.H.A.C.C....but there are more.In MAMEWAH, just point to your catver.ini in the 'Emulator Settings' > 'List Generation Settings' section. Refresh the list and you will then be able to view+filter by said categories
Don't forget EmuTron.www.pacmanfan.com
Quote from: Minwah on June 29, 2003, 07:02:52 pmFrom Triggerfins catlist site http://www.mameworld.net/catlist, here are the FE's that support it:Advance MenuArcade@HomeEmulaxianEmu LoaderMAME FEgRustibusGXMameMAMEWAHMAME WizardMCMQuickPlayS.H.A.C.C....but there are more.In MAMEWAH, just point to your catver.ini in the 'Emulator Settings' > 'List Generation Settings' section. Refresh the list and you will then be able to view+filter by said categories Don't forget EmuTron.www.pacmanfan.com
Quote from: PacManFan on June 30, 2003, 11:23:32 amDon't forget EmuTron.www.pacmanfan.comSpeaking of which, hows that update coming along?
actually, i have same error message when i try to refresh my list. subscript runtime error '9'running mamewah v.952b, just downloaded it. any help appreciated. thanksJacob
figured it out! had to change the list generation method. it works now!
JFront also does.But just a mention, there are 2 formats of the file.
