Author Topic: How to install/use Winuae Loader?  (Read 42515 times)
Rowdy
  • Last login:March 22, 2009, 08:47:55 am
« on: March 20, 2009, 03:21:01 pm »
I want to use amigagames in my arcade and winuae loader seems to be the solution. The problem is that I don't understand how to install it and which files I need and where to get them. The readme-file included is a mess. Have searched the net, but it seems not many use amigagames in mame-arcades.
Can anyone help me? Is there a better way to make WinUAE work in Mala?
headkaze
  • 0x2b|~0x2b?
Re: How to install/use Winuae Loader?
« Reply #1 on: March 21, 2009, 06:59:07 am »
Perhaps you should tell us what the problem is exactly? The readme may be messy but it does tell you everything you need.
To simplify things I would recommend you concentrate on the WHDLoad set.
1. Download the WHDLoad set from here. Extract them somewhere (Eg. C:\Roms\Amiga)
2. Download WinUAE Loader from here.
3. Extract the WinUAELoader folder somewhere (Eg. C:\Emulators\WinUAELoader)
4. Downlaod the WinUAE emulator from here. Extract is somewhere (Eg. C:\Emulators\WinUAE)
5. Run WinUAELoader.exe and set the paths (All you need to set are the "WinUAE Exe" to point to the emulator and "WHDLoad Games" to point to your games (Eg. C:\Emuators\WinUAE\WinUAE.exe and C:\Roms\Amiga respectively)
6. Test a game by going to Tools->Run Game "WHDLoad". Select a game and run it.
7. To run a game from your FE you need do it in the following format
WinUAELoader.exe -mode whdload -game "[ROM]"
Replace [ROM] with the variable your FE uses to send the game name. Eg. GameEx uses [ROM] and MaLa uses %Path%%ROM%%EXT%.
NOTE: You will also need the Kickstart ROMs in the correct place but I cannot tell you where you can get them from. As per the readme...
You need to place the Kickstart ROMs into WinUAELoader\WHD\Devs\Kickstarts (these are not included)
Copy them to WinUAELoader\WHD\Devs\Kickstarts\ and rename them as follows
kick34005.A500 <-- Actual ROM (Kickstart v1.3 rev 34.5 (1987)(Commodore)(A500-A1000-A2000-CDTV).rom)
kick34005.A500.RTB
kick40068.A1200 <-- Actual ROM (Kickstart v3.1 rev 40.68 (1993)(Commodore)(A1200).rom)
kick40068.A1200.RTB
kick40068.A4000 <-- Actual ROM (Kickstart v3.1 rev 40.68 (1993)(Commodore)(A4000).rom)
kick40068.A4000.RTB
You also need to have them setup correct for WinUAE (the emulator).
« Last Edit: July 15, 2009, 05:37:01 pm by headkaze »
Rowdy
« Reply #2 on: March 22, 2009, 07:20:11 am »
Thanks for det response. I had mostly done ir right. Now I get the game to run form the tools->Run game in the loader menu, but when I try the command line, nothing happens. I write
winuaeloader -mode whdload -game "some_game.zip"
No error or something. Just nothing. I have whdloadgames and the right path to them. What am I missing?
Rowdy
« Reply #3 on: March 22, 2009, 08:47:55 am »
I got it to work now. Loader is case-sensitive :P That should really be put in to your Readme (if I didn't miss it)
Didn't notice you where the maker of this great tool, Headkaze. You have my thanks for your job.
How is Loader configurating winua for each game? Is it using a default for all games? Is there I way to tweak winuae trough Loader? Getting each game to work perfect is a science in emulators, and a default setting seldom works for all games.
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: March 22, 2009, 01:33:02 pm »
WinUAE uses the GameBase Amiga database to configure all the games. You can edit the WinUAELoader\Data\WHDLoad.xml file to edit the defaults for games.
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
« Reply #5 on: July 14, 2009, 07:12:29 pm »
Dude, if I could buy you a beer right now I would. Just got this set up on my cab with Maximus Arcade and am in heaven! God I miss my miggy. Thanks for the great work!
headkaze
  • 0x2b|~0x2b?
« Reply #6 on: July 17, 2009, 04:20:27 pm »
Glad you like it ;) BTW There is a donation link on my website (in my sig) and I will always graciously accept one for a few beers :cheers:
Todd H
  • It's Gameday!
« Reply #7 on: July 17, 2009, 04:32:32 pm »
You go it.  :cheers:
headkaze
  • 0x2b|~0x2b?
« Reply #8 on: July 17, 2009, 09:13:15 pm »
Thanks Todd!  :cheers:
tony.silveira
  • Last login:February 18, 2026, 09:58:05 pm
    • my baby
« Reply #9 on: May 25, 2010, 02:19:27 pm »
hey kaze,
sorry to start up an old thread.  trying to set this up myself and running into issues.
1. Download the WHDLoad set from [url=http://kgwhd.whdownload.com/]here[/url]. Extract them somewhere (Eg. C:\Roms\Amiga)
2. Download WinUAE Loader from [url=http://headsoft.com.au/index.php?category=winuaeloader]here[/url].
4. Downlaod the WinUAE emulator from [url=http://www.winuae.net/]here[/url]. Extract is somewhere (Eg. C:\Emulators\WinUAE)
i've done all of the above.  when i try to test a game in step 6, the rom window pops up and it says "0 of 2229 games found".  i've triple confirmed that the paths for loader (step 5 above) are all correct
kick34005.A500.RTB
kick40068.A1200.RTB
kick40068.A4000.RTB
i also have the roms in the correct folder, named correctly (i.e. kick34005.a500, etc.) and set up in UAE, which launches by itself.  any help you can give me is appreciated.
« Last Edit: May 25, 2010, 02:39:39 pm by tony.silveira »
ukdesigner
  • Last login:October 16, 2010, 06:46:04 pm
« Reply #10 on: October 14, 2010, 06:20:47 pm »
Do you know where to put the SPS dll so that you can use IPF images of the Amiga games in WinUae please?
Ive read through all the instructions and theres no help anywhere about it?
Cheers.
votality
  • Last login:October 27, 2025, 03:58:20 am
« Reply #11 on: May 20, 2021, 07:49:21 pm »
Who is winuaeloader's author? Is it still maintained?
Hoopz
  • Intellivision Rocks!
« Reply #12 on: May 20, 2021, 08:57:50 pm »
Headkaze is the author. It's mentioned in this thread. And he's still active here as he logged in today.
