Author Topic: TV TUBE  (Read 2087 times)
alienware32
  • Last login:September 26, 2009, 05:28:40 pm
TV TUBE
« on: March 15, 2009, 12:23:04 pm »
is there anyway to make a trysync monitor with a TV tube
grantspain
Re: TV TUBE
« Reply #1 on: March 15, 2009, 02:29:12 pm »
Almost every standard tv crt yoke is rated around 0.900 to 1.8mh which is the standard 15khz(cga) range
almost all the tri sync chassis on the market are rated at 0.300mh
you can put a dual sync chassis on a standard tv crt but not to my knowledge a tri sync
alienware32
Re: TV TUBE
« Reply #2 on: March 15, 2009, 04:35:23 pm »
so the difference is in the yoke
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: TV TUBE
« Reply #3 on: March 15, 2009, 10:24:32 pm »
keeping the orig game monitor's yoke is the best bet.
basically, what is done in multisync computer monitors is switching in/out capcitance in the h sweep for the various freqs.
Ummon
  • Trade Count: (+13)
Re: TV TUBE
« Reply #4 on: March 16, 2009, 05:17:58 pm »
Auw, you make it sound so easy.
Yo. Chocolate.
Stephen Hawking
alienware32
Re: TV TUBE
« Reply #5 on: March 16, 2009, 06:26:01 pm »
what about the picture tube they are all the same
qrz
Re: TV TUBE
« Reply #6 on: March 16, 2009, 10:43:53 pm »
changing a modern crt really isn't that difficult .  just take your time, be careful and methodical...
there are some variations in cut off voltage - but, that usually isn't a problem.
and most will have identical pinouts for same size /type.
am a liitle familiar with the process.  ;)
over the years , have repaired many a tv ...
used to be an ASC for panasonic/quasar, sony, zenith/lg, rca
the oldest tv repaired to date was a 1948 zenith.  and a fun challenge it was !!  8)
qrz
