Author Topic: What are good tools to use.....?  (Read 1016 times)
studmuff
  • Last login:September 30, 2012, 09:40:15 pm
« on: March 14, 2009, 09:05:55 am »
What tools should I use to cut out a coin door hole?  Finished plywood 3/4".
I tried a jigsaw but I was bouncing off the plywood.  I'm obviously not a handyman.
Making a pin cab for vp and fp cab.
Thanks.
Tom.
BobA
  • What Me Worry?
Re: What are good tools to use.....?
« Reply #1 on: March 14, 2009, 09:26:50 am »
If your jigsaw is bouncing you may not have the proper blade in it or are not holding it down correctly.   Make sure you have a good sharp wood cutting blade in it.  Also it is a good idea to drill pilot holes at the corners to make it easier to start the cut.
studmuff
« Reply #2 on: March 14, 2009, 10:20:32 am »
Thanks bob I'll give it a try.
Tom.
studmuff
« Reply #3 on: March 14, 2009, 11:57:53 am »
Jigsaw Worked good!  I actually made  a 3/4" circle with a drill to get me started.  Thanks for the tip Bob.
Tom.
