Author Topic: Cleaning plexiglass  (Read 1249 times)
Nemss316
  • Last login:April 28, 2010, 10:30:00 am
Cleaning plexiglass
« on: March 12, 2009, 05:52:27 pm »
I was told to use rubbing alcohol when cleaning Plexi. Mine just has some spots on it I want to remove, I just wanted to make sure this is the method to use.
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
Re: Cleaning plexiglass
« Reply #1 on: March 12, 2009, 08:14:18 pm »
I wouldn't do it! I use a paper towel with a mild diluted soap & water mixture on it.
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
Pac-Fan
  • Last login:February 05, 2014, 09:30:12 am
« Reply #2 on: March 12, 2009, 08:18:26 pm »
No you shouldn't -- You don't know if it's acrylic (lucite) or polycarbonate based. One is much more reactive to alcohol than the other IIRC.  You will end up creating a dull cloudy haze over it.
Luckily, if caught early, you can remove it with some Novus but that takes a lot of hand polishing and can warp the light passing through (especially noticeable if used over a monitor)
Just use warm water and most home cleaners that are not alcohol, citrus or oil based.  Stuff like 409, Simple Green, Windex all work well.
There are a handful of citrus cleaners that can work to remove sticky stuff but must be tested in a corner first to be sure it wont damage the plastic.
