Author Topic: Neo Geo MVS power question  (Read 2965 times)
sasuke_kun12
  • Last login:March 10, 2009, 09:05:13 pm
  • Its been to long... I'm never leaving this place!
« on: March 10, 2009, 07:07:10 pm »
I recently bought an MV-1F MVS board that I'm planning on converting into a supergun and I had just one question.
America and Japan both have different voltages then to us down under (Australia). You guys run 110V and we Run at 220V. Do I need a step down converter when I plug in a power supply?
Why are all the good, cheap lowboys in brisbane?
grantspain
Re: Neo Geo MVS power question
« Reply #1 on: March 10, 2009, 07:27:26 pm »
depends on your power supply,some can be switched from 115 to 230,others are free range whereby they work on anything from  85 to 285 and other are set only at 115 or 230
nothing to with the mvs board though
what power supply are you using?
sasuke_kun12
« Reply #2 on: March 10, 2009, 08:43:03 pm »
Well I haven't got the board yet, I just wanted to make sure I'm not going to blow up my precious investment.
I was hoping to use just a regular wall wart
Cyberflexx
  • Last login:October 12, 2012, 03:40:10 pm
« Reply #3 on: March 11, 2009, 08:59:14 am »
You could use a computer AT power supply and flip the voltage switch on the back to 220v from 115v.  :dunno
I run a computer power supply in my MVS  4 Slot machine.
What I did was took all the reds and wired them together and made one connection point.  Took all the Yellows and did the same, and again with the blacks.
Yellow is 12volt
Red is 5volt
Black is ground
This was suggested by Ben at www.benheck.com as he did the same thing with his neo geo 4 slot.   Mine works great, no problems at all..
channelmaniac
  • Last login:May 11, 2019, 12:36:18 am
    • Arcadecomponents.com
« Reply #4 on: March 16, 2009, 10:06:50 am »
Regular wall wart? No.
You'll need a regulated power supply - the type for a laptop.
The MVS runs from +5v and +12v. You CAN modify it for +5v only operation. There are instructions out on the tech support section of the neo-geo.com website.
RJ
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs are kept at: http://newlifegames.net/nlg/index.php?board=19.0
