Author Topic: I'm an idiot, smoked my monitor  (Read 2119 times)
shess
  • Last login:January 07, 2021, 04:17:28 pm
« on: March 09, 2009, 04:35:06 pm »
So my 13" WG monitor was working alright except that the picture was really dim and had lots of color smear when you turn up the gain.  So I replaced some parts and put it back together exactly the way it was before.  Well I noticed that a red wire (not the anode) with connector was attached to the flyback and wasn't plugged in before so I looked to see where it might go.  Well there was a single pole on the neckboard labelled V, and I figured that it might be the right spot.  Well after turning it on, I saw smoke coming from the monitor and quickly shut it down.  After removing the wire and powering it back up, I get just a thin horizontal line.  My first guess is that I sent 10k volts to the vertical deflection circuit and killed it.  I looked all over the board and couldn't find anything that looked blackened so I'm not really sure.  Any thoughts?  Also is there any danger I could now be release x-rays or am I safe to use my multimeter on it while the monitor is running?
Thanks,
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: I'm an idiot, smoked my monitor
« Reply #1 on: March 09, 2009, 10:09:55 pm »
could have fried the ic  AND taken out the fused res feeding b+ to the ic.
have a model # so we can ref a print ?
qrz
shess
« Reply #2 on: March 09, 2009, 10:20:05 pm »
Sure, here it is: WG 13K7886.
shess
« Reply #3 on: March 10, 2009, 07:57:03 am »
Even more confusing now, I checked my other k7000 chassis (19" not 13") and that red lead from the flyback is connected to the V pole on the neckboard.  So not sure why it worked without it hooked up and now after connecting it, I fry something.  Maybe it is something completely unrelated or maybe the 13" flyback is different than the 19" flyback.
grantspain
« Reply #4 on: March 10, 2009, 01:43:13 pm »
i would go back and check the parts that you changed,maybe you put a cap in the wrong way
shess
« Reply #5 on: March 10, 2009, 04:10:30 pm »
I only swapped out 3 transistors and I know I put them back correctly.  Maybe the 13" flyback doesn't use that red lead?
grantspain
« Reply #6 on: March 10, 2009, 05:50:59 pm »
worked before,don't work now=something must be either in the wrong place or missing an insulation sheet or a blob of solder across some track
just trying to look at this logically
