Author Topic: Mala - PC Game Problem (Alt+F4)  (Read 1268 times)
iAtoria
  • Last login:August 06, 2019, 10:02:33 am
  • 01101110011001010111011101100010
    • iAtoria
« on: March 08, 2009, 05:20:01 pm »
Here's the problem.  I have a PC game that will only exit if you press ALT+F4.  I am going to have a cabinet configuration with Mala (since it is the easiest to set up for a noob like mwah).  With a keyboard I can easily get back to the front end by pressing Alt+F4 on the keyboard, the problem is that when I have the cab set up I can't have this.  Most games I have use ESC to exit, so I was wondering if there is some kind of shell that will run PC games and then exit via ESC?  Or does someone know the easiest solution to this problem.
unclet
Re: Mala - PC Game Problem (Alt+F4)
« Reply #1 on: March 08, 2009, 06:09:21 pm »
I think MALA offers mapping some "HotKeys" for each emulator.  Perhaps you can indicate "Alt F4" as a hotkey for your emulator using this method.
Here is a link which should have the information you need to learn about "Hotkeys", however, the link is dead.   I just informed Loadman of this problem so perhaps he can fix it soon.
http://mala.arcadezentrum.com/hotkeys.html
« Last Edit: March 08, 2009, 06:13:58 pm by unclet »
iAtoria
    • iAtoria
« Reply #2 on: March 08, 2009, 10:17:16 pm »
Figured it out.
Just set two hotkeys to close:
ALT+F4 = Close
ESC = Close
Now when I have a PC game running I can press ESC and the game will close.  Not sure of the logic behind that but I am assuming:
ALT+F4 = Close = ESC
« Last Edit: March 08, 2009, 10:38:31 pm by atoria »
