Author Topic: TinyXP Rev 09 question  (Read 3805 times)
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
« on: March 07, 2009, 06:14:09 pm »
Hello All,
I'm looking into TinyXP and likes for experimintation only.  ;)
After wiping out the harddrive and starting up TinyXP, it goes through the normal hardware checking process. Then hangs at the 'Setup Is starting Windows' screen. I have done this about 12 times and same result each time.
Anythoughts?
Thanks,
Fordman
brian_hoffman
  • Last login:July 02, 2011, 09:02:20 pm
Re: TinyXP Rev 09 question
« Reply #1 on: March 07, 2009, 10:40:57 pm »
I've seen the same thing, Some report buring at a SLOW speed help. I didn't find that it worked for me tho. Id recommend using NLITE and building your own. :)
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« Reply #2 on: March 09, 2009, 12:08:53 am »
Hello All,
Anythoughts?
Thanks,
Fordman
 I haven't used Tiny XP 09 but regularly use Version 1, 2.
I can tell you 1 and 2 are picky about it being the first partition
on the HD.
I might suggest hiding everthing else ore unplugging if you
have more than 1 hardrive.
I use Nlite as well but I have to admit
if your not going to use the Internet Tiny XP version
1 is extremely stripped down. I Have a old Compaq Presario
500 MHZ I shelled it into a emulator box with Tiny XP 01.
Sorry getting off topic...back on track now.
Don't forget you can actually use Nlite to strip Tiny XP
even further!
Good luck   :)
