Author Topic: Automatic switching of JAMMA boards.  (Read 1283 times)
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« on: June 27, 2003, 07:01:42 am »
Once in a while someone asks about automatically switching JAMMA boards without doing the wire swap. Here it is! It can swap up to 8 boards at the touch of a button. It's 125 bucks but don't think that's too bad considering what it can do. I wonder if it would switch a JPAC as well? Mame and 7 of your favorite unsupported JAMMA boards! *drool*
http://www.multigame.com/jamma.html
If you build a frankenpanel, chances are I don't care for you as a person.
AlanS17
    • AlanS17
Re:Automatic switching of JAMMA boards.
« Reply #1 on: June 27, 2003, 09:27:43 am »
Each game has to have its own "switch board, though" and those are an additional $25. It comes with 2 free but you may buy up to 6 more. That's another $150! My brother was looking into these to make an all-in-one Mortal Kombat machine (all ther MK's together) but the multijamma was too expensive.
So it sounds like $125 when it can really be $275.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: June 27, 2003, 01:16:09 pm »
That's stilla  good price.
BTW, from multijamma
To :   "Sir Poonga" <sirpoonga@hotmail.com>
Subject :   Re: Multi-jamma info
> I have a question about the multi-jamma.  Your site says 'No "dead spots".
> The Controller will only cycle through the number of game boards attached
(2
> to 8), so if you run with less than 8 boards you won't see a black screen
> when switching over "empty" slots.'
> How does it know?  I ask because I want to know if it will recognize the
> jpac from www.ultimarc.com.
In a nutshell, you give it a 'hint'. ;-)  Basically you load the
switchboards starting at one end of the switcher-- there's then a jumper
that tells it how many games total there are (2-8) and the controller will
only cycle through that many games.
The jpac does work with the MultiJAMMA BTW...  I've had a few people use
them with good results so far.
-Clay
Brax
« Reply #3 on: June 27, 2003, 01:42:24 pm »
So you spend another $275!! How much have you spent already? Imagine being able to play some of the modern kick ass games on your cabinet that aren't emulated or may never be......
*drool*
Hrm, it's a shame I don't think I can wire up all the controls I want using JAMMA. (one down side to a rotating control panel :)
SirPoonga
  • Puck'em Up
« Reply #4 on: June 27, 2003, 01:46:59 pm »
Why not?
