Author Topic: any one tried these out? (nintendo SNES and NES stuff)  (Read 4145 times)
daywane
  • GRRRR!
« Last Edit: March 11, 2009, 11:12:03 pm by Peale »
daywane
  • GRRRR!
Re: any one tried these out? (nintendo SNES and NES stuff)
« Reply #1 on: March 01, 2009, 08:23:53 pm »
found some other stuff
new style nes system
I was just looking for a 72 pin fix for my old NES and found this stuff.
« Last Edit: March 11, 2009, 11:13:42 pm by Peale »
daywane
  • GRRRR!
« Reply #2 on: March 01, 2009, 08:36:24 pm »
wonder if light gun only works with NES games?
nothing much in detail on this system
Link
« Last Edit: March 11, 2009, 11:15:12 pm by Peale »
SavannahLion
« Reply #3 on: March 01, 2009, 11:32:28 pm »
Is there a new version of the NoaC? I heard the original was functional but hardly accurate.
Whoah! Did they come out with SNoaC and SoaC's too??
daywane
  • GRRRR!
« Reply #4 on: March 02, 2009, 12:10:31 am »
english please . ???  :dizzy:
SavannahLion
« Reply #5 on: March 02, 2009, 01:25:22 am »
NoaC stands for "Nintendo on a Chip." It's what most of these NES clones use as their core for emulating the NES. For the most part they work, but the chips don't function with 100% accuracy. Colors are sometimes rendered incorrectly, sounds are off, etc. The chips are typically used in off-Asian imports such as the one BenHeck destroyed to make a portable NES. Also the suspected chip Link1, Link 2, used by the NEX System.
SNoaC and SoaC are just possible names for Super Nintendo on a Chip and Sega on a Chip (though it should be GoaC :P )
Lecithin
  • Last login:April 04, 2012, 10:15:48 am
« Reply #6 on: March 02, 2009, 08:49:32 am »
I own multiple of each of the older systems (I owned them, then my GF moved in and brought another) so I haven't played around with these OAC types. I've heard good and bad things. When they work correctly its great but as was said above, not 100% accurate. The last option (the 3 in 1) is appealing simply because if it works its covering 3 systems. As for the others, I'd rather just buy an original that I know will work 100% of the time.
danny_galaga
  • Last login:Today at 05:39:37 am
    • dans cocktail lounge
« Reply #7 on: March 04, 2009, 05:55:39 am »
what a strange combination...
« Reply #8 on: March 04, 2009, 10:13:20 am »
Shorten your links....  geez  :dizzy:
_JMFR
  • Last login:December 02, 2009, 01:54:50 am
« Reply #9 on: March 04, 2009, 03:04:46 pm »
ive got a fc twin. its ok 4 the most part. it refused to play my castlevania 3. i just ended up buying a restored nes. they come with a new 72 pin connector, and can be found on ebay all day long
daywane
  • GRRRR!
« Reply #10 on: March 06, 2009, 07:11:51 pm »
how about showing me how?
SavannahLion
« Reply #11 on: March 07, 2009, 12:41:00 am »
It's easy enough. Let's see if the forum understands proper code tags.
[url=http://long.url.goes/here/Notice/no/quotes.htm]short description goes here[/url]
Voila!
daywane
  • GRRRR!
« Reply #12 on: March 08, 2009, 12:24:19 pm »
I have not a clue  :dunno
SavannahLion
« Reply #13 on: March 08, 2009, 02:42:03 pm »
« Reply #14 on: March 09, 2009, 08:55:45 am »
Those are great for some games... but games that require hardware level timing just don't play right.  Stuff that is really really timing dependent like Punchout become 10x harder if you can finish them at all.
daywane
  • GRRRR!
« Reply #15 on: March 09, 2009, 09:57:46 pm »
About what?
LOL!
no crap I do not understand what you said.
On how to shorten my licks.
not one ounce of a clue
try links for dummy's not links for idiots
meaning......
I have read the windows for dummy's  books
windows for idiots was way over my head.  :cheers:
daywane
  • GRRRR!
« Reply #16 on: March 11, 2009, 10:03:31 pm »
maybe I did not express my self well.
I am not kidding.
I would like to know how to shorten links.
your explanation was Greek to me?  :dunno
I do not understand 1 bit of what you said
knave
« Reply #17 on: March 12, 2009, 12:44:17 pm »
This is an example what to type to make a link.
Voila!
You just start by typing a bracket thingy " [ "
Then type the letters "u r l" and so on. Where the "http:" begins is where you paste the site you are linking to. Then you close with the other bracket thingy " ] " Type the description you want and finalize with "[/url]. I'm sure you can figure it out with some practice.
