Author Topic: Working with Metal Cabinets/Control Panels  (Read 4774 times)
m3talslug
  • Last login:February 07, 2007, 04:22:25 pm
  • I want to Build My Own Arcade Controls!!
    • M3talslug's Control Panels
« on: June 26, 2002, 09:40:46 am »
I recently purchased Jap Joysticks and buttons that only mount onto so called "metal" cabinets.
Does anyone know where I can find info on how to work with "metal".  i.e. drilling, cutting, etc.
I also have no idea what kind of metal I'm supposed to be looking for.  Are there any wood alternatives?
Here's a pic of the components I ordered
http://www.riverservice.co.jp/ctrg/017.jpg
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
Grasshopper
Re: Working with Metal Cabinets/Control Panels
« Reply #1 on: June 26, 2002, 10:43:49 am »
Did you order your components directly from Japan? I would be interested to know how much you paid.
I have bought a joystick that is identical to the one numbered 30 in your picture except that it came with a different mounting plate. It's a bit difficult to describe but basically the plate wraps around the joystick. It should enable me to embed the joystick about 1/2" into the underside of a wood panel. If I choose 3/4" wood this will mean I only lose 1/4" of the shaft length.
I would avoid metal if at all possible. I once made some minor modifications to a PC case and I found cutting/drilling metal using home tools very hard work.
It occurs to me that you could mount your joysticks in wood if you mount from the top. I'm not sure what you'd do with the buttons though.
m3talslug
« Reply #2 on: June 26, 2002, 02:05:50 pm »
Here's where you can order direct from Japan
http://www.riverservice.co.jp/index_e.html
you'll find pricing, etc.  They are easy people to deal with.  If you're in canada a place called starburstcoin can import jap controls at a better price.
http://www.starburstcoin.com
I'll consider looking at other thin but strong materials to mount this on.  I think it's going to be too stressful to mount onto metal.
Jakobud
  • Last login:Yesterday at 10:09:01 am
« Reply #3 on: June 26, 2002, 06:01:38 pm »
I don't know about cutting metal, but if you want to drill, just goto Homedepot and ask them for metal drilling drill bits.  And just ask them about cutting while you are at it.
jakobud
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #4 on: June 26, 2002, 11:05:16 pm »
I have swappable metal control panels.  They are a total PITA
but very sturdy.  For joystick holes I recommend a 1 1/8" bi-metal
hole saw and lots of cutting oil.  Check out my site for more
info on cutting metal.
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
