Author Topic: Does anybody play ASO, aka. Alpha Mission, Arian Mission, can't get it to run  (Read 1457 times)
Bender
I'm running mame 127u3 and can't get past the "check menu" screen
any Ideas?
I think I remember playing in an earlier version of mame
severdhed
  • RIP Dinosaur Hippo
i just checked and all 3 run just fine on my mame .124
are you sure you have the correct version of the rom?
Bender
I'm supposed to have the right rom set for .127 I also tried the rom from .128 and sill get the same thing
what happens after the "check menu" screen? do you have to press any buttons to get out of that screen?
severdhed
i just launch the game, it goes through it's cycle and then prompts me to insert a coin.  i insert a coin and press start and it starts playing.
looking at this article, there were some changes to the ROMS for version .127..i dont know if that is related to your problem or not...
http://www.gamerwiki.com/index.php/MAME/0.127
did you enter the service menu (f2) or check the dip switch settings (tab)?  i shut my cabinet down for the night, but i'll look a little closer at it tomorrow.
Bender
yeah I was afraid of that
I think I'll try .128 today and see if it works in that as I'm sure I have the right rom for that
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
That one U version (0.127u3) had a issue that was reported for others in that SNK.C driver... specifically, Ikari Warriors.  I suspect this falls under the same problem and was corrected in 0.127u4 by my testing.
Reference bug:
http://www.mametesters.org/mantis/view.php?id=2242
If you are going to use a mame version, it's typically best to stick to the main releases as the temporary regressions that happen are largely cleaned up by then.
Bender
Reference bug:
thanks for the tip
yeah, just figured it was something like that. The new and old roms work in .128, so I figured it was an issue with .127u3
