Author Topic: Getting Tempest to run on a Wells-Gardner monitor  (Read 2180 times)
TheInformer
  • Newbie
  • Last login:March 16, 2010, 04:49:29 pm
« on: February 25, 2009, 05:00:08 pm »
I use Maximus Arcade as my front end.
I used the MAME Resolution Tool and now most of the games installed in MAME work fine.
I try to run Tempest and get an "Out of Range" message on the monitor.
What settings do I need to make to run Tempest?
Thanks in advance..
Re: Getting Tempest to run on a Wells-Gardner monitor
« Reply #1 on: February 25, 2009, 07:04:41 pm »
If it's a standard resolution monitor then I'd say 640x480.
I found an older version of Mame makes vectors look better on a standard res. monitor (there's more settings). I use v0.99 but it's probably the same in versions up to the big video change (v0.123?).
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: February 26, 2009, 12:08:48 pm »
... the big video change (v0.123?).
0.106.  The Big Video Change happened in that version's u updates, and 0.107 was the first major release with the BVC.
Robin
Knowledge is Power
