Author Topic: Would there be a problem with this setup  (Read 818 times)
HeavyK
  • Last login:April 13, 2009, 01:36:15 pm
« on: February 21, 2009, 10:27:45 am »
Y'all
  Here is what I'm planning on using a LEDwiz, electric ice push buttons, electric ice track ball, 2 u360 controllers (player 1 and 2) and 2 8 way joys (player 3 and 4) and a keywiz.  Will all these work together seamlessly or am I going to run into problems?  Is there an easier way to do a 4 player setup with light up push buttons and a light up trackball, u360s, and 2 8way joys or am I on the right track.  Any help would be greatly appreciated!!!  Thanks in advance.
DaveMMR
Re: Would there be a problem with this setup
« Reply #1 on: February 21, 2009, 05:32:55 pm »
Minus the two extra joysticks, buttons, and Kewiz - that's more or less the setup I'm running.  I haven't had any problems with that combo.  Just keep in mind that if you go with RGB LED's for each buttons, you're using THREE inputs for each.  Oh, and you may want to make sure you have enough USB ports.  For some reason, my LEDwiz was temperamental on the USB hub I used (though it may have been the particular brand).
